MSFS2020 - Unable to change options in the Buttons/Switches/Rotar... area of the tool.
As per attached picture no options are available to select in the Buttons/Switches/Rotar... area of the tool window. All options are grayed out.
Please let me know what I'm doing wrong?
Thank you for your help.
  • Have you got the aircraft cockpit showing in the flightsim? If not, do that and it should enable.
  • Good morning Steve,
    The aircraft cockpit is showing in the flightsim when I start the app. Still no go on the options. However, you mentioned in another post of mine that " PMDG aircraft are auto configured, so you cannot change anything." I believe that explains why they are grayed out.
    Thank you.
    A.P.
