EngravityCDUInterface Error 202
After computer crash I am reinstalling all soft of my homemade 737 cockpit. Have problems with your inferface, CDU in green, simconnect red and aircraft blinking red. P3d v4, PMDG 737 NGX, Cpflight all running ok. I´ve reinstalled simconnect at least four times without success. Now I found another problem, error 202 exceed install counts... Need help please.
My account is ec_cdg@yahoo.es.
Thanks a lot,
Julio.
Thanks a lot,
Julio.
Thanks a lot for update licenses. Since today I´ve been very busy and can´t test it again. Some improvement get but don´t works yet.
Now I have all three buttons in green mode, but aircraft and simconnect goes to red after a few seconds, returning to green and again to red, both.
Any idea what happens? Don´t understand because was running well before computer crash. Think I am making so old for software problems...
Here is the log:
3:18:06 MainViewModel: CDU0 Starting.....
3:18:06 SimConnectWrapper: SimConnect Message Processing Started
3:18:06 LockheedMartin.Prepar3D.SimConnect.SimConnect: Start Event Received!
3:18:06 MainViewModel: Event Received: Aircraft Type Changed
3:18:06 LockheedMartin.Prepar3D.SimConnect.SimConnect: SIM, 1
3:18:07 LockheedMartin.Prepar3D.SimConnect.SimConnect: PAUSE, 1
3:18:07 AircraftInterfaceNGX: Left CDU Data Received
3:18:12 LockheedMartin.Prepar3D.SimConnect.SimConnect: PAUSE, 0
3:18:16 CDU0: Status Changed:
3:18:16 SimConnectWrapper: SimConnect Message Processing Finished
3:18:18 MainViewModel: CDU0 Starting.....
3:18:18 SimConnectWrapper: SimConnect Message Processing Started
3:18:18 LockheedMartin.Prepar3D.SimConnect.SimConnect: Start Event Received!
3:18:18 MainViewModel: Event Received: Aircraft Type Changed
3:18:18 LockheedMartin.Prepar3D.SimConnect.SimConnect: SIM, 1
3:18:18 LockheedMartin.Prepar3D.SimConnect.SimConnect: PAUSE, 0
3:18:18 AircraftInterfaceNGX: Left CDU Data Received
3:18:23 LockheedMartin.Prepar3D.SimConnect.SimConnect: PAUSE, 1
3:18:28 CDU0: Status Changed:
3:18:28 SimConnectWrapper: SimConnect Message Processing Finished
3:18:29 MainViewModel: CDU0 Starting.....
3:18:29 SimConnectWrapper: SimConnect Message Processing Started
3:18:29 LockheedMartin.Prepar3D.SimConnect.SimConnect: Start Event Received!
3:18:29 MainViewModel: Event Received: Aircraft Type Changed
3:18:29 LockheedMartin.Prepar3D.SimConnect.SimConnect: SIM, 1
3:18:29 LockheedMartin.Prepar3D.SimConnect.SimConnect: PAUSE, 1
3:18:29 AircraftInterfaceNGX: Left CDU Data Received
3:18:32 LockheedMartin.Prepar3D.SimConnect.SimConnect: PAUSE, 0
3:18:39 CDU0: Status Changed:
3:18:39 SimConnectWrapper: SimConnect Message Processing Finished
3:18:40 MainViewModel: CDU0 Starting.....
3:18:40 SimConnectWrapper: SimConnect Message Processing Started
3:18:40 LockheedMartin.Prepar3D.SimConnect.SimConnect: Start Event Received!
3:18:40 MainViewModel: Event Received: Aircraft Type Changed
3:18:40 LockheedMartin.Prepar3D.SimConnect.SimConnect: SIM, 1
3:18:40 LockheedMartin.Prepar3D.SimConnect.SimConnect: PAUSE, 0
3:18:40 AircraftInterfaceNGX: Left CDU Data Received
3:18:41 LockheedMartin.Prepar3D.SimConnect.SimConnect: PAUSE, 1
3:18:50 CDU0: Status Changed:
3:18:50 SimConnectWrapper: SimConnect Message Processing Finished
3:18:52 MainViewModel: CDU0 Starting.....
3:18:52 SimConnectWrapper: SimConnect Message Processing Started
3:18:52 LockheedMartin.Prepar3D.SimConnect.SimConnect: Start Event Received!
3:18:52 MainViewModel: Event Received: Aircraft Type Changed
3:18:52 LockheedMartin.Prepar3D.SimConnect.SimConnect: SIM, 1
3:18:52 LockheedMartin.Prepar3D.SimConnect.SimConnect: PAUSE, 1
3:18:52 AircraftInterfaceNGX: Left CDU Data Received
3:19:02 CDU0: Status Changed:
I´ve checked cp210 driver port settings, 38400bd, CDU set at 38400 too and interface 38400.
Thanks a lot for your help.
Regards.
Thanks a lot and regards.
Julio
9:22:36 MainViewModel: CDU0 Starting.....
9:22:36 SimConnectWrapper: SimConnect Message Processing Started
9:22:37 CDU0: Status Changed:
9:22:38 CDU0: Message Received: 2
9:22:40 LockheedMartin.Prepar3D.SimConnect.SimConnect: Start Event Received!
9:22:40 MainViewModel: Event Received: Aircraft Type Changed
9:22:40 LockheedMartin.Prepar3D.SimConnect.SimConnect: SIM, 0
9:22:40 LockheedMartin.Prepar3D.SimConnect.SimConnect: PAUSE, 0
9:22:51 MainViewModel: Event Received: Aircraft Type Changed
9:22:53 MainViewModel: Event Received: Aircraft Loaded/Flight Loaded
9:22:56 LockheedMartin.Prepar3D.SimConnect.SimConnect: PAUSE, 1
9:23:04 LockheedMartin.Prepar3D.SimConnect.SimConnect: PAUSE, 0
9:23:05 LockheedMartin.Prepar3D.SimConnect.SimConnect: SIMSTART, 0
9:23:05 LockheedMartin.Prepar3D.SimConnect.SimConnect: SIM, 1
9:23:05 AircraftInterfaceNGX: Left CDU Data Received
Thanks a lot,
Julio
Also, obvious point, but is the screen brightness set OK?
If yes to both, double check you have the CDU, the CP210 driver and the interface all have the same settings.
Brightness understand is same as shown with S+EXEC on CDG, I mean, if I can see the configuration settings on CDU I must see same when exit don´t? Or there is an brightness cfg on interface settings ?
I tried to change port from 4 to 10 with same results.
Again, thanks a lot for help.
Julio.
10:19:55 MainViewModel: CDU0 Starting.....
10:19:55 SimConnectWrapper: SimConnect Message Processing Started
10:19:55 LockheedMartin.Prepar3D.SimConnect.SimConnect: Start Event Received!
10:19:55 MainViewModel: Event Received: Aircraft Type Changed
10:19:55 LockheedMartin.Prepar3D.SimConnect.SimConnect: SIM, 1
10:19:56 LockheedMartin.Prepar3D.SimConnect.SimConnect: PAUSE, 0
10:19:56 AircraftInterfaceNGX: Left CDU Data Received
10:19:56 CDU0: Status Changed:
10:19:56 CDU0: Exception of type 'A.+CommErrorException' was thrown.
10:19:56 CDU0: Message Received: 2
10:22:27 CDU0: Key Pressed: $PCDUKEY,LS6*50
10:22:27 CDU0: Message Received: LS6
Thanks a lot again for help.
Julio.
