Need help to get MCP PRO working
I need help to get my gf mcp pro and efis working with x plane 11. I downloaded the GIT and all i am getting is that pipe connect failed message. I have seen in posts that others were having this issue but since i am not so good at configuring, some help to guide me would be great!
Jay
  • Hi Jay,
    Its either because the GIT plugin has been installed into the wrong X-Plane directory or your firewall is blocking communication between GIT and the GIT plugin.
    During GIT install, you are prompted to confirm the location of the X-Plane directory for the plugin, so re-run setup and confirm it.
    Ok thanks i will try this now and report back
    Jay
  • Steve,
    So i have installed the GIT into the x plane directory, it named it X plane 12. I am just confused where i need to put my folders, do i put them all in the x plane directory ?
    Regards.
    Jay
  • In X-Plane 12\Resources\plugins you should see the GIT Plugin directory.
