GIT not loading any Aircraft files
Starting P3D v5.4 and loading a 3rd party aircraft - Xtreme Prototypes Lear 45. When GIT starts all three LEDs turn green but no aircraft profile is loaded. Just the generic one. The only enabled option is Restart but that doesn't load the profile.
Tried for 3 other aircraft and same problem. How best to resolve please Steve. Log below...
0:36:51 GoFlight Connection Starting.....
10:36:51 SimConnect Connection Starting.....
10:36:52 SimConnect Message Processing Started
10:36:52 GoFlight Connection Started
10:36:52 SimConnect Connection Started
10:36:52 Aircraft Connection Starting.....
10:36:55 WinSock: Connected To localhost On Port 27015!
10:36:55 LUA Processor: Started!
10:36:59 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
10:36:59 Aircraft Connection Started
10:36:59 Simconnect Version: 4.5.0.0
10:36:59 Aircraft FullName: Generic
10:36:59 Synchronising Switches & Selectors .....
10:36:59 Synchronising Switches & Selectors: Waiting for SimConnect .....
10:37:47 SimConnect Message Processing Finished
10:37:48 GoFlight Connection Starting.....
10:37:48 SimConnect Connection Starting.....
10:37:49 GoFlight Connection Started
10:37:49 SimConnect Message Processing Started
10:37:50 SimConnect Connection Started
10:37:50 Aircraft Connection Starting.....
10:37:53 WinSock: Connected To localhost On Port 27015!
10:37:53 LUA Processor: Started!
10:37:57 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
10:37:57 Aircraft Connection Started
10:37:57 Simconnect Version: 4.5.0.0
10:37:57 Aircraft FullName: Generic
Ray (Cheshire, England)
10:51:54 GoFlight Connection Starting.....
10:51:54 SimConnect Connection Starting.....
10:51:55 SimConnect Message Processing Started
10:51:55 GoFlight Connection Started
10:51:55 SimConnect Connection Started
10:51:55 Aircraft Connection Starting.....
10:51:55 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
10:51:55 SimConnect: Event Received: SIM, 1
10:51:55 SimConnect: Event Received: PAUSE, 0
10:51:55 SimConnect: Event Received: VIEW, 2
10:51:58 WinSock: Connected To localhost On Port 27015!
10:51:58 LUA Processor: Started!
10:52:02 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
10:52:02 Aircraft Connection Started
10:52:02 Simconnect Version: 4.5.0.0
10:52:02 Aircraft FullName: XP_Gates_Learjet_25_v3_Retrofitted
10:52:02 Synchronising Switches & Selectors .....
10:52:02 SimConnect: Event Received: SIMSTOP, 0
10:52:02 SimConnect: Event Received: SIM, 0
10:52:02 SimConnect: Event Received: SIMSTART, 0
10:52:02 SimConnect: Event Received: SIM, 1
10:52:02 LvarNamesUpdated!
10:52:02 Creating Bespoke Vars
10:52:02 Bespoke Vars Created
10:52:02 Importing Bespoke Variables
10:52:02 Bespoke Vars Assigned, Importing Bespoke Events
10:52:02 Bespoke Events Temp Imported
10:52:02 Bespoke Events Import Exception: Event _Lear25_Inverters_On, Task Set failed - Specified argument was out of the range of valid values.
10:52:02 Bespoke Events Import Exception: Event _Lear25_Inverters_Off, Task Set failed - Specified argument was out of the range of valid values.
10:52:02 Bespoke Events Import Exception: Event _Lear25_Landing_Light_On, Task Set failed - Specified argument was out of the range of valid values.
10:52:02 Bespoke Events Import Exception: Event _Lear25_Taxi_Lights_On, Task Set failed - Specified argument was out of the range of valid values.
10:52:02 Bespoke Events Import Exception: Event _Lear25_Landing_Light_Off, Task Set failed - Specified argument was out of the range of valid values.
10:52:02 Bespoke Events Import Exception: Event _Lear25_Taxi_Lights_Off, Task Set failed - Specified argument was out of the range of valid values.
10:52:02 Bespoke Events Import Exception: Event _Lear25_TaxiLight_Toggle, Task If failed - Specified argument was out of the range of valid values.
10:52:02 Bespoke Events Import Exception: Event _Lear25_TaxiLight_Toggle, Task Set failed - Specified argument was out of the range of valid values.
10:52:02 Bespoke Events Imported
10:52:02 Loading Aircraft Settings
10:52:02 GetXMLConfigData
10:52:02 GotXMLConfigData
10:52:02 Loading Power
10:52:02 Loading MCPPRO
10:52:02 Loading EFIS
10:52:02 Loading P8
10:52:02 Loading T8
10:52:02 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFT8 0 0 4 LIGHT - Specified argument was out of the range of valid values.
10:52:02 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFT8 0 0 7 LIGHT - Specified argument was out of the range of valid values.
10:52:02 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFT8 1 0 1 LIGHT - Specified argument was out of the range of valid values.
10:52:07 Loading RP48
10:52:07 Loading MESM
10:52:07 Loading WP6
10:52:07 Loading LGT
10:52:07 Loading LGT II
10:52:07 Loading GF46
10:52:07 Loading GF45
10:52:07 Loading TQ6
10:52:07 Loading DIO
10:52:07 Loading GF166
10:52:07 Loading SECM
10:52:07 Loading Joysticks
10:52:07 Clearing Displays
10:52:07 Reset Data
10:52:07 Aircraft Settings Loaded
10:52:07 Calling Aircraft Changed
10:52:07 Aircraft Changed
10:52:10 Synchronising Switches & Selectors Complete
I set a value of 1000000.000000 for MAX_TEXTURE_REQUEST_DISTANCE and it had unintended consequences. I was getting black buildings with the default of 100000.000000 and found a post on AvSim that recommended 320000.000000. That resolved the black buildings but others said they had set it to the value I tried. Obviously it has unintended consequences if set too high.
It couldn't load the aircraft profile with that very high value. It reverted to a generic model which is useless. Reverting to 320000.000000 fixed the problem.
Don't ask me why a texture setting should affect a third party program but it did. Any SimConnect experts out there?
I've now allocated all LPs to it and it loads the aircraft config correctly. Just one question Steve. If I change aircraft a couple of times GIT recognises the first change and loads the relevant aircraft file.
But on second and subsequent changes of aircraft it sticks at Generic. Is that a bug?
For whatever reason SSNG won't launch the new version I installed this morning. Manual launch necessary. Anything changed to cause that? Do you recommend using all available LPs for GIT?
I switch between aircraft all the time and not seen the problem. Can you confirm it started with the new release and that running it manually doesn't solve the problem.
I’ll report back tomorrow with an update.
