MSFS 2024
Will the Goflight interface tool also be supported in MSFS 2024?
I would have at least expected some sort of notification in regards to FS2024 by now.
your username
\AppData\Local\Packages\Microsoft.Limitless_8wekyb3d8bbwe\LocalCache\Packages\Community. Started up FS2024 and then GIT and everything worked.If this doesn't work for you, please provide more info/logs etc.
I will get a new installer out over the weekend, unless other problems are found in the meantime.
Any ideas?
Konrad
If you still have issues start a new discussion and post a copy of your GIT log.
