X-Plane Beta Test - Please post bugs here!
Please post all X-Plane Beta bugs in this thread.
will try a complete reinstall tomorrow
It looks like the plugins didn't compile properly for the final build. I have just rebuilt them and tested. A new version is now available for download.
Fetching plugins for C:\X-Plane 10/Resources/plugins
Loaded: C:\X-Plane 10/Resources/plugins/PluginAdmin/64/win.xpl (xpsdk.examples.pluginadmin).
C:\X-Plane 10/Resources/plugins/GIT Plugin/64/win.xpl : Error Code = 126 : Den angitte modulen ble ikke funnet.
Download and install the following:
https://www.microsoft.com/en-us/download/details.aspx?id=48145
Not sure what I can do about that. X-Plane decides what the heading will be based on the command being sent. X-Plane is handling the heading logic so I think its a bug in X-Plane.
Hi Slayer,
All I've done at this point is expose the X-Plane Plugin API in a friendly manner. I'm new to X-Plane development but having worked with SimConnect, the X-Plane API appears to be no where near as intelligent as SimConnect.
Take the Heading issue you detailed; this is basic stuff and should just work but it doesn't. Yes I could probably write a work-around but why doesn't it work correctly in the first place?
Sending a Command should handle all the decision making specific to the aircraft just like SimConnect does; but X-Plane doesn't seem to do that.
PS. The acceleration function is coded as GIT controls that. It's working for me, can you double check please. Thx
There are still simconnect references in the code where I haven't rewritten functions for X-Plane yet such as Detective, Bespoke Events etc. The simconnect library is embedded into the software so it shouldn't be erroring looking for the assembly.
Can you confirm you have downloaded the correct version.
OK, I'll have to find out why the embedded simconnect is not working.
Both installed in the same directory GoFlight.
Programme finds Go flight and x-plane with green lights also finds the aircraft I am flying
but have a flashing red light in the aircraft column and crashes with
type initializer for"A." threw an exception
Tried to attach zip but it wouldn't let me. hope this is some help
************** Exception Text **************
System.TypeInitializationException: The type initializer for 'A.' threw an exception. ---> System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.FlightSimulator.SimConnect, Version=10.0.61259.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The specified module could not be found. ---> System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.FlightSimulator.SimConnect.dll' or one of its dependencies. The specified module could not be found.
at System.Reflection.RuntimeAssembly.nLoadFile(String path, Evidence evidence)
at System.Reflection.Assembly.LoadFile(String path)
at A.
.(String )
at A..(Object , ResolveEventArgs )
at System.AppDomain.OnAssemblyResolveEvent(RuntimeAssembly assembly, String assemblyFullName)
--- End of inner exception stack trace ---
at A...cctor()
at A.
at A.
.(Object , EventArgs )
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.34209 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
GoFlight Interface Tool X-Plane
Assembly Version: 0.1.1.0
Win32 Version: 0.1.1.0
CodeBase: file:///C:/Program%20Files%20(x86)/GoFlight/GoFlight%20Interface%20Tool%20X-Plane.exe
System
Win32 Version: 4.0.30319.34238 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
GoFlight Interface Tool X-Plane&
Assembly Version: 1.0.0.0
PresentationFramework
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
LedControl
Assembly Version: 0.5.395.0
Win32 Version: 4.0.30319.34251 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.CSharp
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Win32 Version: 4.0.30319.34234 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Anonymously Hosted DynamicMethods Assembly
Assembly Version: 0.0.0.0
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
System.Dynamic
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Dynamic/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Dynamic.dll
PresentationFramework.Aero
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
PresentationFramework-SystemXml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
UIAutomationTypes
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
SharpDX.DirectInput
Assembly Version: 2.4.2.0
SharpDX
The following is in there, if this is any help.
Something I have missing somewhere.
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: GoFlight Interface Tool X-Plane
Problem Signature 02: 0.1.1.0
Problem Signature 03: 55dac83e
Problem Signature 04: mscorlib
Problem Signature 05: 4.0.30319.34209
Problem Signature 06: 534894cc
Problem Signature 07: 272f
Problem Signature 08: 12
Problem Signature 09: System.IO.FileNotFoundException
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
The simconnect error cannot be resolved as I would have to distribute simconnect.dll which would be illegal.
For those with no FSX installation, you will have to wait for the final release that will have all simconnect references removed.
Downloaded today the latest for Xplane. Tried opening GIT and get a Microsoft.Net Framework error.
"the type initializer for "A" threw an exception.
Tried multi scans for any virus, no luck
oswindow7
If you don't have FSX installed, it crashes. You need to wait for a new version that has all the simconnect/FSX code removed.
Yes. There is still some FSX code that needs to be changed to support X-Plane and provide the Detective functionality. Until that is done, systems with only X-Plane installed wont work with the Beta.
Are you still working on the X-Plane version ?
Same to you Trev. Yes I am, but I've had very little spare time the past few months so my plans have gone astray. I do intend to complete X-Plane support.
