Import has failed: Data at the root level is invalid...
Running into a few issues.
Issue 1
To replicate:Aircraft: CS L1011
In detective
After mapping some events, do an export
Exit GIT, exit P3D
Start GIT, start P3D
In detective
Import the file exported
Result: Import has failed: Data at the root level is invalid. Line 1, position 1.
Issue 2
If P3D panel serialization is enabled, every defined mapping will produce an "Out of Range" error. I think this is when the values are actually being removed/deleted from file.
Issue 3
Inconsistency in events appearing in Detective event window. I can't find any consistency, sometimes the events will show sometimes they don't ... setting the polling interval doesn't seem to make much of a difference. In addition, the event list will sometimes just go blank, as if overloaded and just stops updating (even at the longest polling interval) ... or the entire listbox will just flash rather than scroll events.
OS: Win10
FS Platform: P3D V3.1
Cheers, Rob.
Hi rob,
Issue 1 is odd as the import/export routine hasn't changes in ages!
Issue 2 - I don't understand what you mean.
Issue 3 - You can overload detective. Make sure you have filtered out all the noise before turning up the polling interval to max.
Hi Rob,
I have hopefully fixed issue 1. Try an export an import again with this version:
https://www.dropbox.com/s/wdjqnj54jh6tftq/GoFlightInterfaceToolP3D_Setup_2_1_18_7.zip?dl=0
Hi Rob,
I have just tried the panel serialisation on a default aircraft with no problems using the version of GIT in the above post. Can you check to see if using 2.1.18.7 has also fixed this issue. If not can you name a few other aircraft that cause it as I don't have the L1011.
Hi Rob,
I think issue 2 is now resolved.
