Majestic Q400 EFIS and MCPPro profile
I've been working on this off and on for quite a while. Most of the stuff you expect to work does. Included is a .jpg to illustrate the control mapping.
Hopefully in the future I will add much more for others with more hardware than myself.
Can you export your profile using this version https://www.dropbox.com/s/wdjqnj54jh6tftq/GoFlightInterfaceToolP3D_Setup_2_1_18_7.zip?dl=0 which should stop this error being seen by some users http://www.pollypotsoftware.org.uk/support/forum.html#/discussion/312/dash8-and-p3d-v2-4-and-3-1
Steve,
Have you tried this file in P3D v3 as someone is having trouble loading it in?
Can you try renaming My Documents\GoFlight Interface Tool so your settings become unavailable for GIT and then try importing your profile for the Q400 and using it. You can obviously then delete the newly created My Documents\GoFlight Interface Tool and change the renamed one back to get your settings back.
Rob said the xml file needed CR/LF added to each line as he has had similar problems with another aircraft. The new version of GIT does that but it still appears that the problem remains.
Appreciate your time on this as I don't have the Q400 installed at the moment.
Thanks for trying that. I'll let him know.
I'm not sure what it is. As I have said to Rob the export/input function hasn't changed in ages. We do now have P3D v3 deviating from the FSX standard and Windows 10 with its odd little bugs so who knows?!
Thanks for the info. I have been baffled by some of the issues appearing lately and your explanation could be it. I didn't do an upgrade to Windows 10, I did a clean install as well and saw no issues.
What edition/version no. of the Q400 are you using Steve?
