Use these GoFlight drivers. It fixes a bug that effects GIT: https://www.dropbox.com/s/qj9l968zsp7313p/GFConfigSetup_2_26_5.zip?dl=0
What version of GIT are you using?
Also when did the problem start? Have you tried renaming My Documents\GoFlight Interface Tool? Which aircraft is loaded and which Flight Sim?
Neither version 2.5 nor 2.3.
see error message in the file
mfg
Klaus
I have reset your install count to zero so you should be able to register the program now.
Below i have wrote what i have done and the Log-file from PMDG 737 and Airbus and two Pictures.
I start the GIT then the FSX. After load the PMDG 737 or 777 the GIT freeze.
see the Log-file below and the GIT 3 file.
16:24:26 GoFlight Connection Starting.....
16:24:26 SimConnect Connection Starting.....
16:24:27 GoFlight Connection Started
16:29:43 SimConnect Message Processing Started
16:29:43 SimConnect Connection Started
16:29:43 Aircraft Connection Starting.....
16:29:46 FSUIPC: Connection Failed: No connection could be made because the
target machine actively refused it 127.0.0.1:8385
16:29:46 Aircraft Connection Started
16:29:46 Simconnect Version: 10.0.61259.0
16:29:46 Synchronising Switches & Selectors .....
16:29:46 Synchronising Switches & Selectors: Waiting for SimConnect .....
16:29:56 SimConnect: Event Received: Start
16:29:56 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
16:29:56 SimConnect: Event Received: SIM, 0
16:29:56 SimConnect: Event Received: PAUSE, 0
16:29:56 SimConnect: Exception Received: OUT_OF_BOUNDS
When i start the Aerosoft Airbus the Log-file looks below but i become an
error message see GIT 2 file and the GIT doesn´t run.
16:37:31 GoFlight Connection Starting.....
16:37:31 SimConnect Connection Starting.....
16:37:32 GoFlight Connection Started
16:37:49 SimConnect Message Processing Started
16:37:49 SimConnect Connection Started
16:37:49 Aircraft Connection Starting.....
16:37:52 FSUIPC: Connection Failed: No connection could be made because the
16:37:52 Aircraft Connection Started
16:37:52 Simconnect Version: 10.0.61259.0
16:37:52 Synchronising Switches & Selectors .....
16:37:52 Synchronising Switches & Selectors: Waiting for SimConnect .....
16:38:01 SimConnect: Event Received: Start
16:38:01 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
16:38:01 SimConnect: Event Received: SIM, 0
16:38:01 SimConnect: Event Received: PAUSE, 0
16:38:01 SimConnect: Exception Received: OUT_OF_BOUNDS
16:39:04 SimConnect: Event Received: Aircraft Type Changed
16:39:04 GoFlight Connection Starting.....
16:39:04 SimConnect Message Processing Finished
16:39:04 SimConnect Connection Starting.....
16:39:05 GoFlight Connection Started
16:39:05 SimConnect Message Processing Started
16:39:05 SimConnect Connection Started
16:39:05 Aircraft Connection Starting.....
16:39:07 FSUIPC: Connected!
16:39:07 Aircraft Connection Started
16:39:07 Simconnect Version: 10.0.61259.0
16:39:09 SimConnect: Event Received: Start
16:39:09 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
16:39:09 SimConnect: Event Received: SIM, 0
16:39:09 SimConnect: Event Received: PAUSE, 0
16:41:39 SimConnect: Event Received: SIMSTART, 0
16:41:39 SimConnect: Event Received: SIM, 1
16:42:06 Synchronising Switches & Selectors Complete
Thanks for help
Klaus
OK has it ever worked and if so when did it last work regardless of the version of GIT.
Rename My Documents\GoFlight Interface Tool and start will "clean" settings.
Do you have the very latest versions of the NGX and 77X. The older versions will not work with GIT?
PS. Also did you get prompted at least once to run the GoFlight Interface Module when FSX started?
yes i have the very last version of NGX and 777.
yes i have rename the My Documents\GoFlight Interface Tool folder.
yes i once to run the GoFlight Interface Module when FSX started.
but it frezze.
and here the last log-Picture
Thanks for help
Klaus
I can see a Goflight worker thread error which is a critical error. What Goflight hardware do you have and list their quantities please.
1x RP 48
1x GF-LGT
1x GF166a
1x GF- T8
Thanks, I will replicate your setup tomorrow to recreate the issue and feed back to you.
Mfg
Klaus
Hi Klaus,
I cannot re-create the error you have, therefore we need to start with the basics.
I need you to do the following:
1) Uninstall the GoFlight drivers and the GoFlight Interface Tool and delete the directory C:\Program Files (x86)\Goflight
2) Rename My Documents\GoFlight Interface Tool to My Documents\GoFlight Interface Tool Off
3) Install the 2.26.5 GoFlight drivers into C:\GoFlight (do not install into the default location).
4) Install GIT into C:\GoFlight (do not install into the default location)
5) Start FSX and select the Beech Baron and get to the Virtual Cockpit.
6) Start GIT, select the MCP PRO and click FS Default.
7) Quit GIT
8) Start GIT and test that the MCP Pro display and rotaries work OK.
9) Report any problems and the error log to me. Do not do anything else before reporting back to me. Also confirm the GoFlight Interface Module was prompted during FSX startup
Problem my GFConfig doesn´t start. i have send you the install log from the GF-Config.
That is probably the reason why my GIT does not start correctly
a picture and the GIT Log will be also.
Mfg
Klaus
Did you remember to rename My Documents\GoFlight Interface Tool? If you did, zip up that directory and attach it to this forum thread.
Ok. I think there must be some old settings from a very old version. Can you go to C:\Users\<your username>\AppData\Local and delete all directories that contain "PollyPot Software" and try it again.
Note that AppData is hidden.
Would you be OK for me to remote control into your PC tomorrow afternoon to look at the issue?
Ok, install Team Viewer https://www.teamviewer.com and send me your code around 2pm GMT. I'll pm you my email address.
This issue has been resolved. FSX users can download a new version of GIT if they have the same issue. P3D/FSX SE users will be able to download it tomorrow.
