  • Use these GoFlight drivers. It fixes a bug that effects GIT: https://www.dropbox.com/s/qj9l968zsp7313p/GFConfigSetup_2_26_5.zip?dl=0
  • i have installed this version and does not work
  • edited June 2016
    What version of GIT are you using?
    Also when did the problem start? Have you tried renaming My Documents\GoFlight Interface Tool? Which aircraft is loaded and which Flight Sim?
  • i have GoFlight and GIT reinstalled but since I can not register the program.
    Neither version 2.5 nor 2.3.
    see error message in the file
    mfg
    Klaus
  • I have reset your install count to zero so you should be able to register the program now.
  • edited June 2016
    Thanks Steve the registration works but the  GIT not. I don`t rename and i load the PMDG 737 or 777 or Aerosoft Airbus 320 and i use FSX.
    Below i have wrote what i have done and the Log-file from PMDG 737 and Airbus and two Pictures.
    I start the GIT then the FSX. After load the PMDG 737 or 777 the GIT freeze.
    see the Log-file below and the GIT 3 file.
    16:24:26 GoFlight Connection Starting.....
    16:24:26 SimConnect Connection Starting.....
    16:24:27 GoFlight Connection Started
    16:29:43 SimConnect Message Processing Started
    16:29:43 SimConnect Connection Started
    16:29:43 Aircraft Connection Starting.....
    16:29:46 FSUIPC: Connection Failed: No connection could be made because the
    target machine actively refused it 127.0.0.1:8385
    16:29:46 Aircraft Connection Started
    16:29:46 Simconnect Version: 10.0.61259.0
    16:29:46 Synchronising Switches & Selectors .....
    16:29:46 Synchronising Switches & Selectors: Waiting for SimConnect .....
    16:29:56 SimConnect: Event Received: Start
    16:29:56 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    16:29:56 SimConnect: Event Received: SIM, 0
    16:29:56 SimConnect: Event Received: PAUSE, 0
    16:29:56 SimConnect: Exception Received:  OUT_OF_BOUNDS
    When i start the Aerosoft Airbus the Log-file looks below but i become an
    error message see GIT 2 file and the GIT doesn´t run.
    16:37:31 GoFlight Connection Starting.....
    16:37:31 SimConnect Connection Starting.....
    16:37:32 GoFlight Connection Started
    16:37:49 SimConnect Message Processing Started
    16:37:49 SimConnect Connection Started
    16:37:49 Aircraft Connection Starting.....
    16:37:52 FSUIPC: Connection Failed: No connection could be made because the
    16:37:52 Aircraft Connection Started
    16:37:52 Simconnect Version: 10.0.61259.0
    16:37:52 Synchronising Switches & Selectors .....
    16:37:52 Synchronising Switches & Selectors: Waiting for SimConnect .....
    16:38:01 SimConnect: Event Received: Start
    16:38:01 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    16:38:01 SimConnect: Event Received: SIM, 0
    16:38:01 SimConnect: Event Received: PAUSE, 0
    16:38:01 SimConnect: Exception Received:  OUT_OF_BOUNDS
    16:39:04 SimConnect: Event Received: Aircraft Type Changed
    16:39:04 GoFlight Connection Starting.....
    16:39:04 SimConnect Message Processing Finished
    16:39:04 SimConnect Connection Starting.....
    16:39:05 GoFlight Connection Started
    16:39:05 SimConnect Message Processing Started
    16:39:05 SimConnect Connection Started
    16:39:05 Aircraft Connection Starting.....
    16:39:07 FSUIPC: Connected!
    16:39:07 Aircraft Connection Started
    16:39:07 Simconnect Version: 10.0.61259.0
    16:39:09 SimConnect: Event Received: Start
    16:39:09 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    16:39:09 SimConnect: Event Received: SIM, 0
    16:39:09 SimConnect: Event Received: PAUSE, 0
    16:41:39 SimConnect: Event Received: SIMSTART, 0
    16:41:39 SimConnect: Event Received: SIM, 1
    16:42:06 Synchronising Switches & Selectors Complete
    Thanks for help
    Klaus
  • edited June 2016
    OK has it ever worked and if so when did it last work regardless of the version of GIT.
    Rename My Documents\GoFlight Interface Tool and start will "clean" settings.
    Do you have the very latest versions of the NGX and 77X. The older versions will not work with GIT?
    PS. Also did you get prompted at least once to run the GoFlight Interface Module when FSX started?
  • yes it has always work at last with version 2.3.
    yes  i have the very last version of NGX and 777.
    yes i have rename the My Documents\GoFlight Interface Tool folder.
    yes  i once to run the GoFlight Interface Module when FSX started.
    but it frezze.
    and here the last log-Picture
    Thanks for help
    Klaus
  • I can see a Goflight worker thread error which is a critical error. What Goflight hardware do you have and list their quantities please.
  • 1x MCPPRO
    1x RP 48
    1x GF-LGT
    1x GF166a
    1x GF- T8
  • Thanks, I will replicate your setup tomorrow to recreate the issue and feed back to you.
  • Thanks for Info.
    Mfg
    Klaus
  • edited June 2016
    Hi Klaus,
    I cannot re-create the error you have, therefore we need to start with the basics.
    I need you to do the following:
    1) Uninstall the GoFlight drivers and the GoFlight Interface Tool and delete the directory C:\Program Files (x86)\Goflight
    2) Rename My Documents\GoFlight Interface Tool to My Documents\GoFlight Interface Tool Off
    3) Install the 2.26.5 GoFlight drivers into C:\GoFlight (do not install into the default location).
    4) Install GIT into C:\GoFlight (do not install into the default location)
    5) Start FSX and select the Beech Baron and get to the Virtual Cockpit.
    6) Start GIT, select the MCP PRO and click FS Default.
    7) Quit GIT
    8) Start GIT and test that the MCP Pro display and rotaries work OK.
    9) Report any problems and the error log to me. Do not do anything else before reporting back to me. Also confirm the GoFlight Interface Module was prompted during FSX startup
  • Hallo,Steve
    Problem my GFConfig doesn´t start. i have send you the install log from the GF-Config.
    That is probably the reason why my GIT does not start correctly
    a picture and the GIT Log will be also.
    Mfg
    Klaus
  • Did you remember to rename My Documents\GoFlight Interface Tool? If you did, zip up that directory and attach it to this forum thread.
  • i have rename it but this directory is always empty
  • take a look it must be the right directory but the two folder are empty
  • Ok. I think there must be some old settings from a very old version. Can you go to C:\Users\<your username>\AppData\Local and delete all directories that contain "PollyPot Software" and try it again.
    Note that AppData is hidden.
  • have i done but nothing helps
  • Would you be OK for me to remote control into your PC tomorrow afternoon to look at the issue?
  • Yes it is Ok.
  • Ok, install Team Viewer https://www.teamviewer.com and send me your code around 2pm GMT. I'll pm you my email address.
  • This issue has been resolved. FSX users can download a new version of GIT if they have the same issue. P3D/FSX SE users will be able to download it tomorrow.
