FF 777 assigning A/P engage pushbutton to mcp pro X-Plane
Hi folks,
as this is my first ever post in a forum I hope to do it right...
My problem is to assign the A/P engage switch if FF777 to my mcp pro.
The detective shows 2 datarefs for this action: "anim/33/switch = 0" on the first clck and "anim/33/switch = 1" on the second click.
This is a normal push button, it only engages the autopilot. Why are there two different dataref values when clicking as this ONLY ACTIVATES the A/P ?
I have started working with GIT two dys ago and love it!!! But I still need to learn a lot.
Running X-Plane 11.05r2 and GIT latest version (Nov.16 release)
Any explanation would be highly appreciated!
Thanks in advance
Alex
Thanks in advance
Alex
That dataref stores the state of the A/P engage button. It has a value of 1 if its on and a value of 0 if its off.
You may be interested to know there is full config for the FF777 MCP PRO and EFIS in the download section of this website.
thanks for your answer! I think you misunderstood me though: 1st time I click dataref = 1 (on) which is ok;
2nd click is dataref = 0 but A/P is still on! A/P can only be disc. via disc button!
This is what makes me unsure what to assign!
1. A/P arm dataref1 A/P is now on
2. disco via disco button A/P is off
3. A/P rearm dataref0!!! A/P is on again
4. disco via disco button A/P is off
this procedure goes on and on, so if I assign dataref 1 I can only arm once until I reassign dataref 0 for on, which gives me another arming...
Am I thinking a wrong way or is rhis to be done via a kind of loop?
Alex
You can backup your work by making a copy of Documents\GoFlight Interface Tool before doing the above.
I will work on your advice and keep you informed.
BTW: Great support, great Software, very quick response, just completely different than mentioned in some forums which has kept me away from using GIT for a long time until now
Slayer´s bespokes work pretty fine! A/P is manageable now and some more assignments are done perfectly. (gonna read them out for sure to learn from his work)
Only one trouble left for now: The CPT´s PFD is completely dark now after importing the bespoke events... as I´m not a programmer I have no idea for the moment what to do to bring it back to life again (All displays are on and brightness up to max...
as I said: still learning
Greetings
Alex
I only keep an eye on the avsim forum, it would be useful to know if its worth watching out on some other forums?!
Not sure why it has gone dark. I will take a look and see if I can find out why.
no need to investigate, I´ve restarted the sim and GIT several times and now the black scn is gone, things are just fine now!
Thanks for all your help, you are a great supporter! If you want to get mad you should carefully watch the x-plane.org forum... there is a big lot of work to do bc. people write stupid things like "no support" , "nothing works", "waste of money",... And posts like those kept me away from GIT for a long time which I now deeply regret! And I am surely not the only one!
And for all those functions - even updated permanently - the price is very correct in my eyes!
PollyPot rocks my world into new dimensions, got another 4 goflight modules today and can`t wait to install them
With best greetings from Salzburg/Austria
Alex
