Zibo 737 APU start
Trying to tether the APU start switch to a button. There must be something I am not getting because it seems so straight forward.
Run detective, monitor for 30 secs, detected hide, etc....
Then I flip the APU switch in the sim and get:
OFF = laminar/B738/spring_toggle_switch/APU_start_pos DataRef Data: 0
ON - laminar/B738/spring_toggle_switch/APU_start_pos DataRef Data: 1
Start - laminar/B738/spring_toggle_switch/APU_start_pos DataRef Data: 2
I create a bespoke and set it to 0, 1, or 2 and I get no movement from the switch at all using the "Test bespoke event" button.
What am I doing wrong?
Any help appreciated.
Dave
Dave
I'll look into it when I get back in front of my PC later today. It could be that the datarefs are read only.
Those datarefs are read only - the developer decided that, nothing I can do about it.
However, when investigating I noticed there are some Commands for moving the apu switch up and down. They are:
laminar/B738/spring_toggle_switch/APU_start_pos_up
laminar/B738/spring_toggle_switch/APU_start_pos_dn
You could assign these directly to a switch or rotary, or use them in a Bespoke Event that reads the state of the dataref to determine if the Command should be sent. You will find these Commands in the Command section of Detective with the Custom button selected.
I'll look at adding some sort of indication in Detective to identify read only datarefs in the next release.
I used these two for the "if" statements and the commands for the action I wanted.
Now, I am trying to get the switch to move to the "start" position;(using another button)
This is the process I don't get, the only thing that shows up in the window when I move the switch is the dataref showing position 2. That is, as you said "read only". How do I find the command that coincides to make the switch move? Is it just trial and error?
Dave
Switch laminar/B738/spring_toggle_switch/APU_start_pos
case 0:
send laminar/B738/spring_toggle_switch/APU_start_pos_up
case 1:
EndSwitch
Did you get the switch to move to the start(2) position?
I got the on(1) and off(0) positions sorted out with ifs and gotos. My issue is that for the life of me I can't get the switch to move from the on(1) position to the start(2) position. Tried switch/case and ifs/gotos. No luck.
Dave
Just done a test and the APU switch is spring loaded on the Start position, so when its released it springs back to ON.
I simply built a Bespoke Event that sent the laminar/B738/spring_toggle_switch/APU_start_pos_dn twice and the APU did start, although the switch in the VC never actually moved past ON or it at least happened so fast that it appeared to never move past ON.
Thanks Steve, that worked. Still curious about the inner workings and why we can't get the switch to move.
On to the next one!
Dave
