Available from version 2.0.1049.0 using included updated backend dll.
These events are only available for aircraft that use C++ guages with mouse rectangles configured to trigger an event or custom code.
Aircraft that only use XML based guages will not show any Mouse Click Events.
How To Use
Mouse Click Events can only be used within a Bespoke Event created in Detective.
Mouse Click Events can be viewed in Detective via the Events section of the screen, by clicking the "Mse Clks" button. All the known Mouse Click Events are listed. The format is the gauge name followed by the actual file containing the gauge.
Many guage names will repeat, however each one of them is unique and will represent a particular mouse click spot for the guage concerned and thus perform a different action.
To use a Mouse Click Event, create or use an existing Bespoke Event. Click the Send or Send Var button with the required Mouse Click Event selected. You will then be prompted to chose which mouse action you wish to send e.g. MOUSE_FLAG_LEFTSINGLE represents a single left mouse button click. Then click OK.
Once complete Test and assign your Bespoke Event to the required hardware.
