I am more than happy to share your work on the website and credit your effort. To create a package that will work with the Import Wizard, follow these steps:
  1. Create a temporary directory.
  2. In Detective, click the export button. Leave the filename as it is, but change the directory to the temporary directory. Save the file.
  3. For each GoFlight device type you have configured, select the appropriate tab in GIT, select the relevant device number and then click Export. Leave the filename as it is, but change the directory to the temporary directory. Save the file. Repeat for the other device numbers before moving on and repeating for the next GoFlight device type.
  4. If you have used Lua scripts, start the Lua Console and click the export button. Leave the filename as it is, but change the directory to the temporary directory. Save the file. Note that Lua scripts are exported as a single zip file.
  5. If the config files are for the FS2020 version of GIT, copy the Documents\GoFlight Interface Tool\Known Lvars.xml file into the temporary directory.
  6. Once all the GoFlight devices have been exported, select all the files in the temporary directory and create a zip archive file.
  7. Either attach the file in a new thread in the forum or email This email address is being protected from spambots. You need JavaScript enabled to view it.. Ensure you include the aircraft name, developer name and version.
