IMPORTANT: The GoFlight drivers are NOT needed when using the GoFlight Interface Tool for X-Plane. However if you are running Windows 8 or Windows 10 you may need to install the drivers so that it can make registry changes that allow the LED's and displays to work. Once working OK, the GoFlight drivers can be removed.
If the LED's and Displays are still not working after doing the above, double check that you only have USB2 or USB1 ports connected to the GoFlight hardware. Note that ALL connections in between the GoFlight hardware and the PC must be USB 2 or USB1. If the problem remains, use Windows Explorer to go into the GoFlight drivers directory, right click on Windows8Fixer.cmd and select Run As Administrator. If this does not fix the problem, remove ALL GoFlight hardware and repeat; then reconnect the GoFlight hardware. Repeat this process until it all works. If the issue remains, try the hardware on a Windows 7 (or below) PC to check the hardware isn't faulty and if it is OK, contact GoFlight Inc for support.
1) Install the Goflight Interface Tool by opening the zip file and double clicking the setup executable. After accepting/changing the installation directory, you will later be prompted for the X-Plane directory path of the version of X-Plane you wish to use with this software. Accept the found directory or alter as necessary.
2) For DRE Mimic Mode to work, the DataRef Editor Plugin must be physically removed from X-Plane. Disabling it will not work.
3) Start the Goflight Interface Tool XPlane from the desktop by clicking the relevant icon, or by clicking the Windows Start button, All Programs, Goflight Interface Tool folder and then the Goflight Interface Tool X-Plane.
4) Once the Registration window appears, copy and paste the User Key ( available via Shop, My Account, My Profile ) and click Register.
4a) If registration is successful the software will start. If unsuccessful, please ensure that no spaces exist before and after the pasted User Key.
4b) If registration problems persist, click the small "i" button in the Registration window to obtain an installation code. Email the installation code along with your Registration error code and order details to This email address is being protected from spambots. You need JavaScript enabled to view it..
NOTE THAT THE DEVICE TABS ONLY BECOME ENABLED ONCE THE FLIGHT SIM HAS BEEN STARTED AND THE VIRTUAL COCKPIT IS SHOWING!
