Bespoke Events and Variables serve exactly the same purpose as Standard Commands and DataRefs except you create them yourself by using the Detective functionality within the GoFlight Interface Tool. An Event is synonymous to a Command and a Variable is synonymous with a DataRef.
Why use Bespoke Events & Variables?
Many complex aircraft use custom developed code and gauges which cannot be accessed using standard Commands and DataRefs. However by using Detective you can reveal normally hidden internal DataRefs and Commands and then include these in your own Bespoke Event allowing your flight sim hardware to work with custom developed code and gauges.
The normally hidden internal variables are referred to as Custom DataRefs & Custom Commands.
