All example charts are located in My Documents\Nav Data Tool\Examples folder.
These charts MUST be imported and not loaded.
All the charts are based on default FSX scenery. If you have add on scenery for the airports used in the examples that use significantly different ILS radials than the defaults then you may need to alter the heading in ALL the Directions where an ILS is referenced (usually only Approach charts). To do this, change the Hdg to 0 and then retype the ILS identifier into Nav Aid so the newer ILS heading is automatically populated into Hdg. In a later release this issue will be resolved automatically.
EGLL - Heathrow
Contains a full suite of chart types with some very complex SID's and Initial Approaches. The actual charts can be found here.
EGPF - Glasgow
Contains some complex SID's only. The actual charts can be found here.
KJFK - Kennedy International
Contains a single STAR which uses transitions. The actual charts can be found here.
PAFA - Fairbanks International
Contains SID's, STAR's and Approaches. The actual charts can be found here.
