IMPORTANT: If you are running Windows 8/Windows 10 or Windows 11 and the LED's and Displays are not working, double check that you only have USB2 or USB1 ports connected to the GoFlight hardware. Note that ALL connections in between the GoFlight hardware and the PC must be USB 2 or USB1. If the problem remains, use Windows Explorer to go into the GoFlight drivers directory, right click on Windows8Fixer.cmd and select Run As Administrator. If this does not fix the problem, remove ALL GoFlight hardware and repeat; then reconnect the GoFlight hardware. Repeat this process until it all works. If the issue remains, try the hardware on a Windows 7 (or below) PC to check the hardware isn't faulty and if it is OK, contact GoFlight Inc for support.
1) Install the Goflight Interface Tool by opening the GIT MSFS.zip file and double clicking the setup.exe.
2) The MSFS Community folder seems to vary from system to system. If you cannot see a directory called pollypotsoftware-flightsimio-module in your Community folder, download and unzip the GIT MSFS Module file and unzip its contents into the Community folder.
 3) Double check any programs that you use to interface with GoFlight hardware, have been disabled or their configurations do not duplicate what you intend to do with the GoFlight Interface Tool. E.g. FSUIPC, LINDA. Note there is full compatibility with FSUIPC with the correct settings.
 4) Start MSFS.
 5) Start the Goflight Interface Tool from the desktop by clicking the relevant icon, or by clicking the Windows Start button, All Programs, Goflight Interface Tool folder and then the Goflight Interface Tool.
 6) Once the Registration window appears, copy and paste the User Key ( available via Shop, My Account, My Profile ) and click Register.
7a) If registration is successful the software will start. If unsuccessful, please ensure that no spaces exist before and after the pasted User Key.
7b) If registration problems persist, click the small "i" button in the Registration window to obtain an installation code. Email the installation code along with your Registration error code and order details to This email address is being protected from spambots. You need JavaScript enabled to view it..
