GoFlight P8
Auto Throttle Disengaged Warning
Button Event: ON, EVT_DSP_CPT_AT_RESET_SWITCH
Button Data: MOUSECLICKTOGGLE
Light Data: DATA_FWDPAN_LIGHT_AT_LEFT
Light Action: ON, Light Value: 1
GoFlight T8
Overhead Panel GEN 1 Switch
Switch Event: ON, EVT_OH_ELEC_GEN1_SWITCH
Switch Data: MOUSELEFT_WITH_OFF
Light Data: DATA_FWDOH_ELEC_LIGHT_GEN_BUS_OFF_LEFT
Using a Switch Action of ON/OFF will not work because the switch has 3 states; 0, 1 and 2. By using the Switch Action of MOUSELEFT_WITH_OFF a mouse left click is sent when the T8 switch is in the ON state but it will also send a right mouse click when the T8 switch is OFF (unlike the MOUSELEFT Action which does not transmit an OFF state and is best used with push buttons).
GoFlight RP48
Autobrake
Rotary Event: CLOCKWISE, EVT_MPM_AUTOBRAKE_SELECTOR
Rotary Action: ROTATE
The two LED lights underneath the rotary can be set to display whether the AUTO BRAKE state is set and whether it is in a disarmed state. Note that by using the OFF Light Action the lights will always be ON unless the light value becomes 1 in the NGX i.e. the OFF state of the AUTO BRAKE (0: RTO, 1: OFF, 2:1, 3:2 etc.):
First LED Light:
Button Event: NONE
Button Data: NOTHING
Light Data: DATA_FWDPAN_SWITCH_AUTO_BRAKE
Light Action: OFF, Light Value: 1
Second LED Light:
Button Event: NONE
Light Data: DATA_FWDPAN_SWITCH_AUTO_BRAKE_DISARM
GoFlight DIO:
AT Reset Button mapped to a Push Button:
Connector Event: ON, EVT_DSP_CPY_AT_RESET_SWITCH
Connector Action: MOUSELEFT
Logo Light Switch mapped to a Switch:
First Connector:
Connector Event: ON, EVT_OH_LIGHTS_LOGO
Connector Action: ONOFF
Second Connector:
Connector Action: ONOFF_REVERSED
Flaps mapped to a Flap Switch
First Connector:
Connector Event: ON, EVT_CONTROL_STAND_FLAPS_LEVER
Second Connector:
Connector Action: MOUSERIGHT
Captains EFIS Left VOR/ADF Selector Mapped to a 3way Switch
First Connector:
Connector Event: ON, EVT_EFIS_CPT_VOR_ADF_SELECTOR_L
Connector Action: CUSTOM_WITH_OFF_AS1
Custom Value: 0
Second Connector:
Custom Value: 2
Captains EFIS Range Selector Mapped to a 12way Selector
Selector 1:
Connector Event: ON, EVT_EFIS_CPT_RANGE
Custom Value: 0
Selector 2:
Custom Value: 1
Selector 3:
Custom Value: 2
Selector 4:
Custom Value: 3
Selector 5 Onwards:
Keep adding 1 to the value of the previous selectors Custom Value e.g. 4, 5, 6, 7 etc….
AT Arm Light Mapped to an LED
LED Data: DATA_MCP_LIGHT_AT
LED Action: ON
LED Value: 1
