If you haven't backed up the directory Documents\Virtual Flight Sim Hardware Builder, there are automatic backups in the directory called Backup. The Last Known Good Backup in the Backup directory contains the most recent backup, whilst the other directories contain later backups.
  1. Copy the backed up files over the top of the existing files. If you are relying on the automatic backups then do not copy and paste the Backup directory.
  2. If you have backed up C:\ProgramData\Virtual FlightSim Hardware Builder, then copy the backup over the top of the existing files.
  3. If you haven't backed up C:\ProgramData\Virtual FlightSim Hardware Builder:
    1. Run the Virtual Flight Sim Hardware setup program and choose "Re-install Base Data".
    2. Load each of your custom Components, Modules, Device Panels and Device Panel Groups via the File Menu Load option and then select the File Menu Save option to generate the imagery.
