21st November: A new version of the GoFlight Interface Tool for FS2020 is now available.
GIT doesn't see some datarefs FF767 V1.2.6
I'm using the latest version 2.0.14. I have just updated to the new FF767 v1.2.6 and some of the datarefs are no longer seen by GIT. Most alarmingly the 757Avionics/ap/.. heading, alt, speed and vs_act datarefs which feed the display windows of the MCPPRO. There are others too but you get the point. I can see these in Dataref Editor and they are there in GIT when I boot up the old 767 V1.1.32. So obviously something has changed with the new version of the plane but is there a way to get GIT to see these datarefs so I can get my displays working with the new plane?
Thanks in advance,
p
Thanks in advance,
p
Thanks Slayer,
p
1. How do you know the datarefs aren't seen by GIT? I've noticed that my MCP just doesn't work, but there are no errors.
2. Can you give the list of the exact lines which need to be added to the Dataref.txt file?
3. Is this something we should tell FF to fix in a new release?
thanks,
Wayne
I suspect FF have slightly altered the config files and the GIT pattern matching is not correctly picking up the Datarefs and Commands in some situations. This is why I wanted someone to send me an actual aircraft file (such as an obj file) that contained the Datarefs that are missing so I can update GIT to work with the updated FF. Failing that I guess I will have to buy the aircraft.
p
I even did a strings plugins/757767Avionics/64/lin.xpl | grep "757Avionics" | sort | uniq on both the new and old aircraft, and barely anything has changed. They have added 5 new variables, and removed "757Avionics/ap/isMachSpdTargetInUse". But apart from that, its all the same.
So I don't have any evidence here that anything has actually been removed or changed. Does the Datarefs.txt file actually do anything? I thought that was generated by X-Plane, but GIT grabs the values directly and doesn't read this file, right?
If there is a specific exact string you want me to look for, I can do that.
thanks,
Wayne
I don't think I'm testing this right. Actually, I've always had problems with GIT not working sometimes, and I don't think I'm using it correctly, or I don't understand its limitations - sometimes I just reboot and re-import and it works, sometimes not. I've read the documentation at https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/99-how-to-load-downloaded-aircraft-configuration-files.html about using configuration files. However, I have some followup questions:
1. Is it possible to switch between say the Zibo 737 and SSG 747 in X-Plane, and GIT will have both config files available and switch automatically? Or is GIT only capable of storing one configuration file in memory? Does it store this across reboots?
2. When you do the import steps, what is it doing exactly and why does it take so long? Is it reloading the MCPPRO device via USB? Does the MCPPRO store the aircraft configuration in the device? Why store everything in the device and not do all the mappings in software?
3. The GIT UI says "MODE: Generic ... 767-200ER_xp11". Then it has green check marks on most options, but red X on GlobalDataRefs, GlobalCommands, DREPrivateDataRefs, and OBJ Commands. Does "767-200ER_xp11" imply that it detected the aircraft correctly? What does "Generic" mean? Should I always have green check marks next to everything?
4. When I run the import wizard, and click the ... to select the file, sometimes it comes up with 777.zip and now it is 767-200ER_xp11.zip - why does it sometimes use the full acf name and others not? ... should the zip always match the aircraft name?
thanks!
Wayne
1) Yes, once its imported, GIT remembers and switches automatically.
2) Import takes a long time as X-Plane has a very poor interface for building add-ons. Unlike Simconnect, GIT has to scan all the files in an aircrafts folder to try and identify datarefs and commands. It does not store anything in the hardware.
3) Generic mode is a non aircraft sdk specific mode. Not everything should be ticked, it's just telling you what it has found to find datarefs and commands.
4) Not sure, but the zip file can be named anything you like, but obviously only import the correct zip file for the aircraft currently loaded as all kinds of wield things could happen.
1. Is there a way to view what profiles GIT currently knows about? What is the correct approach when an aircraft you know has worked before, but doesn't sometimes? (currently I've been just reloading the profile and hoping it works, sometimes it does, sometimes it doesn't)
2. Aircraft like the FF767 seem to have everything baked into a compiled C++ binary blob, and don't support searching through the raw .acf or .obj files, so how do these work? Can't it just read a dataref like sim/aircraft/view/acf_descrip or XPLMGetNthAircraftModel to get the raw aircraft filename which will reveal which one it is?
3. How can we tell if everything is working? It seems like sometimes the MCP just doesn't do anything, and after restarting GIT a few times, or X-Plane, or a reboot, everything works. Sometimes. But no idea how to debug what is going on.
thanks!
Wayne
2) GIT can only get datarefs by scanning text files or by mimicking DRE and hoping the developer has used the DRE facility for declaring datarefs. It does use XPLMGetNthAircraftModel to get the aircraft name. GIT does not handle text datarefs.
3) The profiles are written by customers, I cannot guarantee they will work correctly. Be careful of installing multiple aircraft that end up having the same aircraft name - this could screw things up as the profile is used based on the aircraft name.
As instructed by knightracing, I loaded the FF767 and from within GIT copied his datarefs into the datarefs.txt file, which was totally blank to begin with. Then, I relaunched the sim and the 767 and sought to make some assignments for the GF MCP Pro. I assumed that knightracing's datarefs would appear in the pulldown list. But none are there. Is there a step I'm missing in order to gain access to and use these datarefs?
Thanks for your assistance.
Robert
Robert
You could try extracting the files from the zip file and on the MCP PRO tab with the aircraft loaded, wipe the config and then import the relevant xml file. Alternatively, wipe the config from all devices and in detective wipe all the bespoke events and then run the Import Wizard.
Cleaning out the xml file entries and then running the Import Wizard fixed the problem. Thanks for the help.
Robert
