GF Module tabs not bold and unclickable
Thank you for your efforts with this module. My problem is as follows.
With the interface (Latest version as of today), If I load any aircraft other than the 737NGX, all of the module tabs are grey and unclickable.
If I load the NGX, my GF modules are recognised and fully customisable as designed.
I have thoroughly read the manual and checked that all is as it should be. I have attempted to upload the event log. If I need to do it again, please advise the best way to do this.
Cheers Marty.
Cheers Marty.
Hi Marty,
The tabs only enable when the Interface recieves a sim running event. Normally this occurs during loading a flight or when the VC/2D cockpit is visible.
This was added in the last few releases because not all lvars are available until the sim is in a running state and so configuration was not consistent and error prone.
