Make Set, Send, Set+, Set-, If, Switch context sensitive from right click on Vars/Events.
I eluded to this in my prior request on MseClks. Rather than moving the mouse back and forth between action to perform (Set, Send, If, Switch) use existing context (I'm in the Lvars list for example), right click the desired Lvars in the list and a position sensitive popup with action choices specific to the context of Lvars, select it and enter a value if a value is part of the context.
Cheers, Rob.
Cheers, Rob.
