Where is the Developer bundle purchase option?
Some questions:
1. Unable to find the Add to cart button for the "developer" bundle?
2. Does the VFSH include support for the GoFlight physical modules also so with have use both physical and virtual?
Cheers, Rob.
  • Hi Rob,
    1) I'm just finishing up the X-Plane version as the Developer version will get all versions for every flight sim. I'm very close, so hoping this month.
    2) No. The FlightSimIOServer will be developed to support GoFlight and Virtual so only a single server needs to be running. A common Module/Plugin in the sim will also be available, supporting GoFlight and Virtual (which is done, just needs some final testing) before I release for GIT users. GIT will be developed to use the same Virtual Hardware Builder, but obviously limited in scope.
  • All sounds great Steve ... I'll keep an eye out for Dev version.
    Cheers, Rob.
