global_aircraft.lua and global.lua not executing
Hi all
Totally stuck with this.
I've been running simple lua code that executes fine - but I need it to run in the global_aircraft.lua file on startup. Nothing ever runs, no matter what I try.
Relevant log section:
00:17:03 Synchronising Switches & Selectors
00:17:04 Global LUA Event Running
00:17:04 Global Aircraft LUA Event Running
00:17:04 Synchronising Switches & Selectors Complete
I've created a simple while loop which is supposed to read vars from the sim and output a bespoke var. Even without the loop, I can't even manually execute a 'global'-type lua file.
Any suggestions would be appreciated!
Cheers
