LEVEL UP 737/700/800 xplane 11
Hello! Can anyone perform Provided Bespoke Events for this planes?
  • I'm also hoping for this! Such a beautiful aircraft.
  • I used the config file available for the ZiboMod, and got GF166, GF45 and MCPPro to work. Need some adjustments for some of the MCPpro and EFIS functions, but am at least getting closer to getting everything working correctly.
    Next step will be to export MCPPRO and EFIS configuration while the Zibo is loaded, and then load those in to GIT tool with LevelUp loaded.
    I am hoping that will get the remaining functions to work
  • I got all the modules fully functional with the LevelUp 737, except for the Range and mode selector knobs on the EFIS.
    Not giving up an those though.
  • Okay, I finally got the Range and Mode Selector knobs to work. Took some "Detective" work.
    For some reason, importing the Zibo config .zip file through the Wizard, would not import the Bespoke events, which caused the two knobs not to work.
    After manually re-creating the Bespoke events in "Detective", I got the LevelUp 737-700 working with all modules and functions.
    I did run into a problem importing the created zip file of the -700 in the other LevelUp variants using the Wizard: GIT did a CTD, and it deleted the .zip file and all other files in the temp folder.
    So, I had to individually import the bespoke events, and configs for each GoFlight module individually.
    Once everything was working I exported the Bespoke events and configs for each module and zipped them per LevelUp variant.
    I now have the following GoFlight Modules fully functional with all LevelUp variants: MCPPro, EFIS, 2x GF-166, and a GF-46.
    Now I can go back to flying these beautifully modelled aircraft, while enjoying the use of all my modules.
    I am a happy/camper/flyer again, lol.
    Btw; If the mods want to upload my zip files for others to enjoy, then please reach out to me, and I will gladly share them. But be advised, use will be at their own risk, and I will not provide any further support.
  • Dutchdc3
    can you send LevelUp 737 profile plz
  • Dutchdc3
  • @new4xxx and @pablomas5 I sent you both a msg
  • dutchdc3 i'm still waiting you i didn't get the profile
  • Both @new4xxx and @pablomas5 have received the config files.
  • @Dutchdc3 Do you mind sending it to me also please?
  • @Dutchdc3 My email: santiagoziella11@gmail.com
  • Just use the zibo one's.
    replace the aircraft name
    with or or ...
    they use the same datarefs en Commands.
    Took 5 minutes to map all buttons and make the BespokeEventsXPlane.xml and BespokeVariablesXPlane.xml for the Levelup 737
    Hello, I have the same problem with the EFIS. Can you send me your B737 Levelup file with the correct datarefs?
    My email address: jacques. oziel@gmail.com
    Thank you
  • Hello, I have the same problem with the EFIS. anybody cann send me B737 Levelup file with the correct datarefs?
    alaeddinahmad@hotmail.com
  • Hello,
    I don't check this forum frequently so didn't see the requests for my file.
    @JacquesOziel and @alaeddin1965 I sent you both the file, even though I'm not sure if you still needed it.
    For others requesting my file, please send me a PM.
