The dreaded yellow light simconnect issue 2020
Hello folks, I have researched this issue on the forums. (GIT 2020)
I have both (GIT) and the module installed in the Community Folder and no joy on the sim connect, still yellow.
Here is the log
12:40:09 GoFlight Connection Starting.....
12:40:09 SimConnect Connection Starting.....
12:40:09 SimConnect Message Processing Started
12:40:10 GoFlight Connection Started
12:40:10 SimConnect Connection Started
12:40:10 Aircraft Connection Starting.....
12:40:10 FSX/FSX SE registry AppPath entry not found
12:40:10 SimConnect: Event Received: Aircraft Type Changed
12:40:10 SimConnect: Event Received: SIM, 1
12:40:10 SimConnect: Event Received: PAUSE, 0
12:40:10 Synchronising Switches & Selectors .....
12:40:10 SimConnect Message Processing Finished
12:40:10 GoFlight Connection Starting.....
12:40:10 SimConnect Connection Starting.....
12:40:11 Creating Bespoke Vars
12:40:11 Bespoke Vars Created
12:40:11 Importing Bespoke Variables
12:40:11 Bespoke Vars Assigned, Importing Bespoke Events
12:40:11 Bespoke Events Temp Imported
12:40:11 Bespoke Events Imported
12:40:11 GoFlight Connection Started
12:40:11 SimConnect Message Processing Started
12:40:11 Synchronising Switches & Selectors: Waiting for SimConnect .....
12:40:12 SimConnect Connection Started
12:40:12 Aircraft Connection Starting.....
12:40:12 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
12:40:12 SimConnect: Event Received: SIM, 1
12:40:12 SimConnect: Event Received: PAUSE, 0
12:40:13 WinSock: Connected To 127.0.0.1 On Port 27016!
12:40:13 LUA Processor: Started!
12:40:13 Aircraft Connection Started
12:40:13 Simconnect Version: 11.0.62651.3
12:40:13 Aircraft FullName: PMDG 737-700
12:40:13 SimConnect: Exception Received: OUT_OF_BOUNDS
12:40:13 SimConnect: Exception Received: ILLEGAL_OPERATION
12:40:13 Send Control Data: Too Many Retries
12:40:14 Send Control Data: Too Many Retries
12:40:15 Send Control Data: Too Many Retries
  • I can confirm that I am having the same issue after SU9. Deleted folder in documents and Appdata and the issue persists.
  • I also just had this problem post SU9 but after a complete system reboot it is now working fine with the CRJ700 so I think it is just another manifestation of the dreaded simconnect bug that appears from time to time.
    Neil
    Neil
    Well that is odd, I installed SU9 then the new nvidia driver then did a system restart and the issue was there. After rebooting today after work, it was working, three green! :D
  • Really odd, I am still out to sea
