How Do I Get GIT PMDG 737 Existing Config Settings Active In MSFS for MCP and EFIS?
I have the latest (May 22) GIT version and enabled the MCP and EFIS as Device 0 but the EFIS does nothingand the MCP shows the correct values in the LED windows if I adjust them in the sim (i.e. the altitude shows correctly on my hardware if I set it in the sim) but turning the knobs has no effect. What am I doing wrong? Does the EFIS and MCP still need to be manually programed with Detective? Thank you for any help.
  • When you use the GoFlight gear does the GoFlight Green LED flash on the GIT status tab?
    Can you post your GIT log on here.
  • The GoFlight green light stays steady and doesnt change when turning knobs or pushing buttons. The Simconnect light is steady yellow. I will send the GIT log.
  • Have you Enabled the EFIS in GIT. Send me the log. Thx
