GoFlight devices will not load automatically
I programmed the settings for the GF devices (GF-LGT, GF-MPC, GF-166, GF-T8) on various aircraft (C-172, C-182 Skyline etc.). Unfortunately, the devices do not always start automatically and I have to program everything again. Once everything is reprogrammed, they work again.
Thank you for your help
Greetings Peter
  • Hello Steve
    I asked a question some time ago. But haven't gotten an answer yet. Do you no longer offer support?
    greetings
    Peter
  • Hi
    Sorry for not responding; I've been ill for the past month and only now just getting back into work.
    When it happens next, take a copy of Documents\GoFlight Interface Tool and post it here. Also post the GIT log from the Log tab.
  • Hi Steve
    Can you tell me where the relevant files are located and what the name is.
    Thanks and regards
    Peter
  • Zip up Documents\GoFlight Interface Tool and copy the log from the GIT Log tab.
  • Hello Steve
    I hope this is the correct information you need. The problem occurs on different aircraft. When loading the aircraft, the GF instruments remain dark and I have to re-enter the data each time.
    Greetings Peter
