Goflight MCP on MSFS 2020 with PMDG 737 not working
The GoFlight MCP lights up and when you turn nobs there is no change on MCP but it does change in the Simulator, it was working fine prior to the PMDG 737-700 update back on June 24, 2022, is there a fix for this or a future update? Thank you Rob
3rd party developers are using an unsupported SDK from P3D. As we are preparing the MSFS dedicated SDK there are changes that are made which means some aspects will not work any more until the new SDK is out.
We had been contacted by 3rd party developers and we provided them an intermediate SDK to overcome this issue. I am not aware if the pollypot developer has contacted us.
Chris Makris
Customer & Product Support
PMDG Simulations, LLC
www.pmdg.com
I just got a response from PMDG (see Below) they said that the SDK was sent day it was requested Via a Ticket
The SDK was sent to them from Robert the same day they requested it via a ticket.
Chris Makris
www.pmdg.com
Expect a new GIT version ASAP.
20:19:26 SimConnect Connection Starting.....
20:19:26 SimConnect Message Processing Started
20:19:26 PMDG SDK option is OK in FS2020
20:19:26 SimConnect: Event Received: Aircraft Type Changed
20:19:26 SimConnect: Event Received: SIM, 1
20:19:26 SimConnect: Event Received: PAUSE, 0
20:19:26 GoFlight Connection Started
20:19:26 SimConnect Connection Started
20:19:26 Aircraft Connection Starting.....
20:19:26 SimConnect Message Processing Finished
20:19:26 GoFlight Connection Starting.....
20:19:27 SimConnect Connection Starting.....
20:19:27 Creating Bespoke Vars
20:19:27 Bespoke Vars Created
20:19:27 Importing Bespoke Variables
20:19:27 Bespoke Vars Assigned, Importing Bespoke Events
20:19:27 Bespoke Events Temp Imported
20:19:27 Aircraft Processor: SubscribeToSimObjectEvent Failed
20:19:27 Bespoke Events Imported
20:19:28 SimConnect Message Processing Started
20:19:28 GoFlight Connection Started
20:19:28 Synchronising Switches & Selectors .....
20:19:28 Synchronising Switches & Selectors: Waiting for SimConnect .....
20:19:28 SimConnect Connection Started
20:19:28 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
20:19:28 SimConnect: Event Received: SIM, 1
20:19:28 SimConnect: Event Received: PAUSE, 0
20:19:28 SimConnect: Exception Received: UNRECOGNIZED_ID
20:19:28 SimConnect: Exception Received: DUPLICATE_ID
20:19:28 SimConnect: Exception Received: OUT_OF_BOUNDS
20:19:28 WinSock: Connected To 127.0.0.1 On Port 27016!
20:19:28 LUA Processor: Started!
20:19:28 Aircraft Connection Started
20:19:28 Simconnect Version: 11.0.62651.3
20:19:28 Aircraft FullName: PMDG 737-700
20:19:29 SimConnect: Exception Received: OUT_OF_BOUNDS
DS
20:19:36 SimConnect: Exception Received: OUT_OF_BOUNDS
20:19:47 SimConnect: Exception Received: OUT_OF_BOUNDS
20:19:48 SimConnect: Exception Received: OUT_OF_BOUNDS
20:20:00 Global LUA Event Running
20:20:00 Global Aircraft LUA Event Running
20:20:00 Synchronising Switches & Selectors Complete
20:20:00 SimConnect: Exception Received: OUT_OF_BOUNDS
20:20:19 SimConnect: Exception Received: OUT_OF_BOUNDS
20:20:20 SimConnect: Event Received: SIMSTOP, 0
20:20:20 SimConnect: Event Received: SIM, 0
20:20:21 SimConnect: Event Received: Quit
20:20:21 WinSock: Connected To 127.0.0.1 On Port 27016!
20:20:21 SimConnect Message Processing Finished
20:20:21 LUA Processor: Started!
20:20:21 SimConnect Connection Starting.....
