Goflight MCP on MSFS 2020 with PMDG 737 not working
The GoFlight MCP lights up and when you turn nobs there is no change on MCP but it does change in the Simulator, it was working fine prior to the PMDG 737-700 update back on June 24, 2022, is there a fix for this or a future update? Thank you Rob
  • Hello, Below is the response from PMDG on the Goflight MCP not working, is there going to be an update?
    3rd party developers are using an unsupported SDK from P3D. As we are preparing the MSFS dedicated SDK there are changes that are made which means some aspects will not work any more until the new SDK is out.
    We had been contacted by 3rd party developers and we provided them an intermediate SDK to overcome this issue. I am not aware if the pollypot developer has contacted us.
    Chris Makris
    Customer & Product Support
    PMDG Simulations, LLC
    www.pmdg.com
  • See the other posts on this topic.
  • Steve,
    I just got a response from PMDG (see Below) they said that the SDK was sent day it was requested Via a Ticket
    The SDK was sent to them from Robert the same day they requested it via a ticket.
    Chris Makris
    www.pmdg.com
  • I've just replied to the ticket, saying I haven't got it.
  • Well PMDG said they have sent, I will now stop being the ping pong ball/messenger and not use the simulator for a few weeks until this is sorted out, some of us that have full blown cockpits are probably feeling the same, quite frankly I am a bit disappointed that it would take this long to get this fixed, after all these tools are not freeware. Regards. Rob.
  • They've just released 3.00.0025 as of yesterday.
  • Just got an email from Rob Randazzo at PMDG who said there was a miscommunication and I was overlooked. I now have the SDK, but he has warned me that further updates will probably break the SDK again.
    Expect a new GIT version ASAP.
  • Thank You, will it be announced here on the forum when update is available? Regards. Rob
  • I contacted PMDG about the interim SDK asking if I could have access to it. Chris Makris replied the interim SDK will only be available to developers, but, when they release the 600 version ( not too long now ) the Official SDK will ship with it ( and the 700 version ) for ALL users. So its just a matter of time before this issue gets sorted out, and we can enjoy our GF hardware again, courtesy of Steve and GIT.
  • New version of GIT now available that supports PMDG 737 with updates. Let me know of any issues.
  • Thank you Steve, I just tried the update and it’s now working fine. Regards. Rob.
  • Brilliant news Steve, many thanks for this. I will test and report back.
  • Hello! I have a problem! I donwload the new version of GIT, and everything works, but when I turn nobs there is no change on MCP but it does change in the Simulator... simconnect appear in yellow light... I have PMDG new version (3.0.25). Everything worked ok with version 3.0.19. I update the sdk too... Any solution Steve? Thanks!
  • Copy and paste the full GIT Log from the Log tab here.
  • 20:19:26 GoFlight Connection Starting.....
    20:19:26 SimConnect Connection Starting.....
    20:19:26 SimConnect Message Processing Started
    20:19:26 PMDG SDK option is OK in FS2020
    20:19:26 SimConnect: Event Received: Aircraft Type Changed
    20:19:26 SimConnect: Event Received: SIM, 1
    20:19:26 SimConnect: Event Received: PAUSE, 0
    20:19:26 GoFlight Connection Started
    20:19:26 SimConnect Connection Started
    20:19:26 Aircraft Connection Starting.....
    20:19:26 SimConnect Message Processing Finished
    20:19:27 SimConnect Connection Starting.....
    20:19:27 Creating Bespoke Vars
    20:19:27 Bespoke Vars Created
    20:19:27 Importing Bespoke Variables
    20:19:27 Bespoke Vars Assigned, Importing Bespoke Events
    20:19:27 Bespoke Events Temp Imported
    20:19:27 Aircraft Processor: SubscribeToSimObjectEvent Failed
    20:19:27 Bespoke Events Imported
    20:19:28 SimConnect Message Processing Started
    20:19:28 GoFlight Connection Started
    20:19:28 Synchronising Switches & Selectors .....
    20:19:28 Synchronising Switches & Selectors: Waiting for SimConnect .....
    20:19:28 SimConnect Connection Started
    20:19:28 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    20:19:28 SimConnect: Event Received: SIM, 1
    20:19:28 SimConnect: Event Received: PAUSE, 0
    20:19:28 SimConnect: Exception Received: UNRECOGNIZED_ID
    20:19:28 SimConnect: Exception Received: DUPLICATE_ID
    20:19:28 SimConnect: Exception Received: OUT_OF_BOUNDS
    20:19:28 WinSock: Connected To 127.0.0.1 On Port 27016!
    20:19:28 LUA Processor: Started!
    20:19:28 Aircraft Connection Started
    20:19:28 Simconnect Version: 11.0.62651.3
    20:19:28 Aircraft FullName: PMDG 737-700
    20:19:29 SimConnect: Exception Received: OUT_OF_BOUNDS
    DS
    20:19:36 SimConnect: Exception Received: OUT_OF_BOUNDS
    20:19:47 SimConnect: Exception Received: OUT_OF_BOUNDS
    20:19:48 SimConnect: Exception Received: OUT_OF_BOUNDS
    20:20:00 Global LUA Event Running
    20:20:00 Global Aircraft LUA Event Running
    20:20:00 Synchronising Switches & Selectors Complete
    20:20:00 SimConnect: Exception Received: OUT_OF_BOUNDS
    20:20:19 SimConnect: Exception Received: OUT_OF_BOUNDS
    20:20:20 SimConnect: Event Received: SIMSTOP, 0
    20:20:20 SimConnect: Event Received: SIM, 0
    20:20:21 SimConnect: Event Received: Quit
    20:20:21 WinSock: Connected To 127.0.0.1 On Port 27016!
    20:20:21 SimConnect Message Processing Finished
    20:20:21 LUA Processor: Started!
    20:20:21 SimConnect Connection Starting.....
  • I don´t know if that is your ask me. If it is not, where is the log tab?
  • This is the problem: 20:19:27 Aircraft Processor: SubscribeToSimObjectEvent Failed. Double check you have the pollypot module in your community folder. If not you can download it from your account.
