Xplane Crashes when using detective
Hello,
Xplane11
Windows 10
GFRP-48
B777 300ER Flight Factor
Xplane crashes when I have detective open and select scrolling view > monitor toggle
Thank you for your help
John
  • Does it do this with every aircraft?
  • Hello,
    I'll check.
    Thank you
    John
  • Yes, it crashed when I selected B787 payware and B737 that came with xplane.
    Thank you for the help
    John
  • I have just test tested with the 787 and it worked fine. Do you have Update on Flight Loop ticked in settings as this can cause issues?
    If not, try renaming Documents\GoFlight Interface Tool so GIT starts with a clean config and see if you still have the problem.
