Rich Boll
13:17:40 GoFlight Connection Starting.....
13:17:40 SimConnect Connection Starting.....
13:17:41 SimConnect Message Processing Started
13:17:41 SimConnect Connection Started
13:17:41 Aircraft Connection Starting.....
13:17:41 GoFlight Connection Started
13:17:42 WinSock: Connected To 127.0.0.1 On Port 27016!
13:17:42 LUA Processor: Started!
13:17:42 Aircraft Connection Started
13:17:42 Simconnect Version: 11.0.62651.3
13:17:42 Aircraft FullName: Generic
13:17:55 SimConnect: Event Received: Start
13:17:55 SimConnect: Event Received: Aircraft Type Changed
13:17:55 SimConnect: Event Received: SIM, 1
13:17:55 SimConnect: Event Received: PAUSE, 0
13:17:55 GoFlight Connection Starting.....
13:17:55 SimConnect Message Processing Finished
13:17:55 Synchronising Switches & Selectors .....
13:17:56 SimConnect Connection Starting.....
13:17:56 Creating Bespoke Vars
13:17:56 Bespoke Vars Created
13:17:56 Importing Bespoke Variables
13:17:56 Bespoke Vars Assigned, Importing Bespoke Events
13:17:56 Bespoke Events Temp Imported
13:17:57 Bespoke Events Imported
13:17:57 GoFlight Connection Started
13:17:57 SimConnect Message Processing Started
13:17:57 Synchronising Switches & Selectors: Waiting for SimConnect .....
13:17:57 SimConnect Connection Started
13:17:57 Aircraft Connection Starting.....
13:17:58 Synchronising Switches & Selectors: Waiting for SimConnect .....
13:17:58 WinSock: Connected To 127.0.0.1 On Port 27016!
13:17:58 LUA Processor: Started!
13:17:58 Aircraft Connection Started
13:17:58 Simconnect Version: 11.0.62651.3
13:17:58 Aircraft FullName: PMDG 737-600
13:17:59 Synchronising Switches & Selectors: Waiting for SimConnect .....
13:18:00 Synchronising Switches & Selectors: Waiting for SimConnect .....
13:18:01 Synchronising Switches & Selectors: Waiting for SimConnect .....
13:18:02 Synchronising Switches & Selectors: Waiting for SimConnect .....
13:18:02 SimConnect: Event Received: Start
13:18:02 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
13:18:02 SimConnect: Event Received: SIM, 1
13:18:02 SimConnect: Event Received: PAUSE, 0
13:18:05 Synchronising Switches & Selectors Complete
Best regards, Ralf
https://www.avsim.com/forums/topic/622424-does-the-avia737ng-cdu-not-work-for-the-pmdg-737-600/
GIT 4.7 is working fine for me in MSFS with the PMDG B736 (EFIS and MCP Pro). But I had to manually add
[SDK]
EnableDataBroadcast=1
in the 737_Options.ini file in the B736 Work folder.
I have the MS Store version of MSFS installed on a dedicated drive.
F:\WpSystem\S-1-5-21-2083512862-3558294711-2696691775-1001\AppData\Local\Packages\Microsoft.FlightSimulator_8wekyb3d8bbwe\LocalState\packages\pmdg-aircraft-736\work
My F drive is where I have the Community and Official folders installed.
Worth noting that when I installed the B737-600, GIT 4.7 was already installed and working fine with the B737-700. I did not re-install GIT.
I am OK with GIT 4.7.1.0 for now, until I decide to buy the B738 ;-)
Best regards.
Still have all zeros and no lights on the MPC Pro with latest download.
users/name/appdata/local/packages/microsoftflightsimulator_8wekyb3d8bbwe/localstate/packages/pmdg-aircraft-738/work
Works like a charm Sir!
Thanks Steve.
