Tabs Greyed in Sim Mode
Hello,
I just installed GIT for FSX SE and have been attempting to get it to work with several of my GF modules with no luck. I configured the dll.xml and allowed the file to run upon FSX startup. GIT detects its in Sim Mod (All 3 Lights green), yet all my modules are greyed out. I don't think I missed any steps but maybe I did. Any ideas? The Goflight section lists all my modules accurately.
-Chris
Hi Chris,
You need to be in the virtual cockpit of an aircraft before the tabs become enabled.
Hi Chris,
Just done a quick test with the default Trike and all is OK. I would double check you have the dll loading properly and try another aircraft.
Also, is the Detective button enabled?
I'm not sure if FSX SE reports DLL's crashing. It would be worth following the steps in the FAQ in relation to the Goflight Interface Module.dll crashing just to make sure it is actually loading and not silently crashing out.
Hi Chris,
The FAQ entry is the last one called FSX/P3D/FSX SE Crashes on start up indicating an error with the Goflight Interface Module.
Can you try it with the default Trike.
That key was OK, but no harm done.
I've not seen this problem before.
What other addon's are being loaded in xml.dll and exe.dll? It may be worth just loading the Goflight Interface Module.dll to see if that makes a difference.
Also do other external addon's work like Active Sky so we can rule out simconnect issues?
Have you tried running everything with admin rights or "as administrator"?
I'm struggling to get to grips with what is happening here. If you want, I can teamview into your PC over the weekend at some point and take a look.
I'm at time zone GMT +0 so I guess your afternoon is my evening. Anything prior to 6.00pm GMT would be OK for me. Just email me when you're at your PC with your team view ID and password and I'll take a look.
P.S. I'll email you so you have my email address!
