GF EFIS problem
For several days I have a problm : I only can use 1 of my 2 EFIS in GFT for my PMDG 777 and 747.
When I try GFCONFIG, i see them both.
When I copy the pmdg copnfig file from a backup, I have them at the begining of the flight, then nothing.
Any solution?
Thank's
Yves
  • Was it working Ok before? Are 2 EFIS seen in GIT on the status screen?
  • It was working OK before
    When I copy an old pmdg.xml, it works and I can use both for a short time. After that, or if I do not copy an old pmdg.xml, I can only see one. I have tried to erase the directory in \appdata\local, but no change.
    Thank's
    Yves
  • If GIT is only seeing one EFIS, it will write the config when it quits with only 1 EFIS, hence the problem.
    I'm wondering if it is a power management issue and the other EFIS is going into a suspended state. It would be worth checking your power management settings on the EFIS and all associated hubs and USB ports.
  • I found why : the second EFIS was not recognized in windows. Just a double click on it and no it works fine.
    Thank's a lot for your help
    Yves
