I need Help
Hi every body
I cannot make my GoFlight MCP Pro work at all with GIT
Please some one to help me
When I lauch GITP3DV4
I get a Message
" The previous Save Failed!Have you Replaced The Settings Files With The Backup Files From The Backup Sub Directory
It is the first time I have this message.
Then
I the mane Window shows the three lamps down are different colors
1- Dark Green
2- Green
3- Red
The MCP Dosn't show any Digit
The EFIS Wirks properly
the Landing Gear don't make the UP and OFF
I appologise for my poor english
Thank you for your help
I get a Message
Then
1- Dark Green
2- Green
3- Red
I have the same problem. tried to do as instructed but no change. when I use the Import wizart to import the zip file it gives me that exact message (the previous save failed! have you replaced the settings files with the backup files from the backup sub directory?)
im using XP11.5 with the Zibo mod. trying to install the Zibo 737-800 by David Williams. for use with: TQ6, MCP-Pro, EFIS.
it used to work fine. lately I disconnected my TQ6 for repair and it all got crazy on me.
any other suggestions?
thanks
yaniv
