X Plane 12
2»
  • admin_pps said:
    hello Steeves
    Git 3.0.0.0
    the process stops there and the git pluggin folder is not installed in XPlane 12 /resource/plugin
    w10 -
    thanks for your help
    Roland
    Is the pop up window appearing behind your installer to prompt for the X-Plane 12 directory during setup?
    yes it appears and it is the right way so i clic on yes
  • admin_pps said:
    Application Halted is due to corrupt settings file. Delete C:\Users\\AppData\Local\PollyPot_Software.
    The 20003 errors, can be safely ignored; it's just a notification that the dataref has already been registered. I will need to change that error reporting.
    You cannot connect to Winsock/Lua because the IP address of your PC needs to be set in Lua Config.txt which sits in Documents\GoFlight Interface Tool.
    okj i delete it : same blocking problem
  • edited October 2022
    GIT Plugin did not install. Also Delete C:\Users\\AppData\Local\PollyPot_Software but same result. WIP Plugin, the same no connection.
  • I have just updated GIT again to resolve a critical issue with duplicate dateref monitoring.
    For those still having issues, confirm the plugin exists in plugins\resources.
    Any winsock error showing in the log, is due to the host setting in Lua Config.txt located in Documents\GoFlight Interface Tool. This must be set to your ip address of your PC. This will cause a massive delay in the aircraft LED on the GIT Status tab going green.
    DO NOT INSTALL GIT WITH X-PLANE RUNNING!
    3.0.1 seems to work now.
    Just got issues with my GF166A and my GS-45's were the displays don't work, the rotary and buttons of the GF166 work fine, but I think that is probably not related to GIT but with my new computer, the powered USB hubs, USB 3.2 gen 2, ...
    [Update] Issue was I copied the folder GoFlight from my old computer. I now downloaded the setup (which contains also the drivers), and that solved the issue.
    so with GIT 3.0.1.0
    adress IP of my PC in Lua Config.txt
    always same problem GIT install stuck in same place and nothing in plugin ressource
    Roland
    so with GIT 3.0.1.0
    Roland
    When running GIT setup, are you being prompted to confirm the plugin directory?
  • no juste the path of Xplane 12 for me on C
  • but not ressource > plugin
  • I have still the same error like Roland, and yes klick OK for the Plugin.
  • sorry i dont understand your question : YES i have image
  • Try running setup as Administrator. It may be a security issue so the directories and file cannot be copied. Also make sure X-Plane is not running when running setup.
  • sorry I stop my tests I will resume tomorrow,
    I hope you will find the problem
    a big thank you Steve
    sorry for my english i use google translate for writing
    Roland
  • I have just added the plugin as a separate download in your account, so you can install it manually.
    Hi Steve, I have the same problem. Admin is set and XP is not running. Thanks for your help.
  • Hi Steve, I have the same problem. Admin is set and XP is not running. Thanks for your help.
    Manually install the plugin, its now in your account downloads.
  • Hello Steve ,
    now it's OK
    i have juste turn the botton display on my Efis and MCP and is ok
    for the lua config i leave my adress IP or i put back ''localhost '' ?
    a big thanks
    best regards
    Roland
