X-Plane 11 crash when starting GIT X-Plane
When starting GIT X-Plane, X-Plane 11 crashes. This is a fairly recent trend. It's not all the time, but it's increasingly so.
It occurs with the Felis B747-200. I have GIT running so I can raise the landing gear and a few other things like radios. I've programmed the MCP Pro or EFIS modules. It is consistently crashing on GIT start up after I have the Felis loaded. I've tried different liveries, same thing. I have no problems with Felis crashing expect when starting GIT.
Any thoughts?
Thanks!
Rich Boll
Any thoughts?
Thanks!
Rich Boll
Can you rename Documents\GoFlight Interface Tool and then start GIT. GIT will start with a clean config so nothing is configured. Does the Felis still cause a crash?
I do not have Run selected.
I switched liveries in the Felis and this worked again. It could have been something with Felis, or who knows what!
I did an update with the new XP11 GIT; however, the updated XP11 would start, but it only display the first green light. The other two center and right lights were red and it wasn't connecting to any devices. I'll play with it some more. Thanks!
Rich
If changing livery has helped, then consider if you have the aircraft short name set correctly - perhaps GIT is picking up the wrong aircraft name and thus the wrong config?
