MFS 2020 Goflight 166 PMDG 737
I've bought the Polltpot software in order to use my Goflight 166's with MFS 2020 and especially the PMDG 737.
After starting the Goflight Interface Tool FS2020, the status tab indicates three green lights, but my panel 166 are not working.
What settings should I be using on the 166 tab? Device 0 or 1? Enabled? Nothing seems to have any effect or bring my Goflight radio panels to life.
I am in the cockpit with the power on.
I should be grateful for some advice.
Renzo
  • ok, I have the 166 radios working but the panels are not lit. Any advice?
  • I am posting in the correct place for technical support? I've spent £29.99 on the Goflight Interface Tool and have worked out myself how to get it working with my two GF166's, at least in the PMDG 737 in MFS 2020, but the radio displays are blank? Should I be using a powered USB hub? Does PollyPot themselves help with technical support? Should I send an email?
  • Is there technical support for this product? Please someone answer:)
  • Hi Pod265,
    There is technical support on this site. Steve usually answers, but sometimes he's a bit busy. Give him a little time.
    Rich Boll
  • Thanks Rich. That's all I need to know:)
  • Sorry for the late reply, I have been unavailable due to unforeseen circumstances.
    Assuming the controls are working and the displays are not. Follow the "Important" section here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/263-installation-fs2020.html
    Also, the GF166's are notorious for locking up. This is a GoFlight issue and also occurs with their drivers. You can search this forum for GF166 and see the numerous work arounds people have found.
  • Thanks. I followed your instructions and now my LED's work:)
    Renzo.
