GoFlight MCP Pro not working i MSFS 2020 - PMDG 737-700
Fresh install of MSFS 2020 (updated to SU10) on a brand new SSD drive. Also fresh install of the GoFlight Interface Tool MSFS 2020. I run the program after aircraft load and nothing. MCP doesn't even come on.
09:07:26 GoFlight Connection Starting.....
09:07:26 SimConnect Connection Starting.....
09:07:26 SimConnect Message Processing Started
09:07:26 GoFlight Connection Started
09:07:26 SimConnect Connection Started
09:07:26 Aircraft Connection Starting.....
09:07:26 PMDG SDK option is OK in FS2020
09:07:26 SimConnect: Event Received: Aircraft Type Changed
09:07:26 SimConnect: Event Received: SIM, 1
09:07:26 SimConnect: Event Received: PAUSE, 0
09:07:26 Synchronising Switches & Selectors .....
09:07:26 SimConnect Message Processing Finished
09:07:27 SimConnect Connection Starting.....
09:07:27 Creating Bespoke Vars
09:07:27 Bespoke Vars Created
09:07:27 Importing Bespoke Variables
09:07:27 Bespoke Vars Assigned, Importing Bespoke Events
09:07:27 Bespoke Events Temp Imported
09:07:27 Bespoke Events Imported
09:07:28 SimConnect Message Processing Started
09:07:28 GoFlight Connection Started
09:07:28 Synchronising Switches & Selectors: Waiting for SimConnect .....
09:07:28 SimConnect Connection Started
09:07:28 Aircraft Connection Starting.....
09:07:28 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
09:07:28 SimConnect: Event Received: SIM, 1
09:07:28 SimConnect: Event Received: PAUSE, 0
09:07:29 WinSock: Connected To 127.0.0.1 On Port 27016!
09:07:29 LUA Processor: Started!
09:07:29 Aircraft Connection Started
09:07:29 Simconnect Version: 11.0.62651.3
09:07:29 Aircraft FullName: PMDG 737-700
09:07:30 Global LUA Event Running
09:07:30 Global Aircraft LUA Event Running
09:07:30 Synchronising Switches & Selectors Complete
