No detective for PMDG aircraft
When selecting the PMDG 737NGX in P3D 2.5, the Aircraft LED keeps flickering green and the Detective button is disabled. Aircraft shows NGX PMDG 737-800NGX. For standard P3D aircraft everything works fine.
This is the log window:
18:55:21 GoFlight Connection Starting.....
18:55:21 SimConnect Connection Starting.....
18:55:22 GoFlight Connection Started
18:55:22 SimConnect Message Processing Started
18:55:22 SimConnect Connection Started
18:55:22 Aircraft Connection Starting.....
18:55:22 PMDG SDK option is OK in Prepar3D
18:55:22 SimConnect: Event Received: Aircraft Type Changed
18:55:22 SimConnect: Event Received: SIM, 1
18:55:22 SimConnect: Event Received: PAUSE, 0
18:55:22 SimConnect Message Processing Finished
18:55:22 GoFlight Connection Starting.....
18:55:23 SimConnect Connection Starting.....
18:55:23 GoFlight Connection Started
18:55:24 SimConnect Message Processing Started
18:55:24 SimConnect Connection Started
18:55:24 Aircraft Connection Starting.....
18:55:24 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
18:55:24 SimConnect: Event Received: SIM, 1
18:55:24 SimConnect: Event Received: PAUSE, 0
18:55:25 Aircraft Connection Started
18:55:25 Simconnect Version: 1.4.0.0
18:55:25 Synchronising Switches & Selectors .....
18:55:25 SimConnect: Exception Received:  ERROR
18:55:28 Synchronising Switches & Selectors Complete
-Emile.
  • Hi Emile,
    Detective does not work with the NGX or 77X as GIT links directly to the PMDG SDK's. All PMDG events and variables are built in, just select them. Online user guide has all the details.
  • Thanks for the clarification, that makes sense.
    -Emile.
