2.1.12
I down loaded the version 2.1.12 for FSX and found that it works the controls but none of the LED lights work. Even on the MCP the displays were zero, but the knobs changed the numbers on the PMDG NGX.
I also saw the even though I downloaded version 2.1.12, the version showing up is after I unzipped it was 2.1.11.1 is this correct?
Anyway I went back to the old version and that works fine for now..
Terry
  • Hi Terry,
    I'm using GIT 2.1.12.0 right now with the NGX and FSX with no problems. The version is incorrect in the code as I forgot to update it, but it really is v 2.1.12.0
  • Hi Terry,
    Its worth noting, the NGX needs SP1D now for GIT to work!
    Best wises
  • I have all the up dates to NGX from PMDG and I also have the update from Go-Flight I think is 2.25.
    When I install the update 2.1.12 all switches work just the displays on the MCPpro and the LED's do not work. All buttons and knobs work the aircraft but just no displays on any goflight equipment. I have tried re installing 3 times with no luck. Version 2.1.10 works fine just some clusters are are not working properly.
    Terry
  • Are you sure you are running SP1D? Its not a service pack, its a new full installer from PMDG released 2 weeks ago.
  • Yes, I had to go to PMDG and install it like a new aircraft, plus in the PMDG operations center it says all up to date, my current version number for my NGX is 1.10.6436 and states up to date in the operation center. That is how I knew there was an update to the NGX was from the ops center.
    Now unless I am missing something I think it is all up to date..
    Terry
