Simconnect
Hi
in my application, the SimConnect lamp lights up yellow.
What can I do?
Greetings Peter
  • Hello Steve
    Can it be that the update makes this error? I think the error happened to me after the update.
    Please send me a solution to the problem.
    Greetings Peter
  • Have you followed the installation instructions txt file in the setup zip file? If yes, post your GIT Log.
  • I hope it's the right one.
  • No, copy the log from the GIT tab called Log.
  • I suspect the GIT WASM module is out of date in your community folder. Manually install it (its available from your account).
  • Is this the right one?
  • Yes. Does GIT actually still work even though the light is yellow?
  • That's what it looks like.
    git.jpg 37.9K
  • OK, you need to copy and paste your whole GIT Log, not just the top bit.
  • 17:44:10 GoFlight Connection Starting.....
    17:44:10 SimConnect Connection Starting.....
    17:44:10 SimConnect Message Processing Started
    17:44:10 GoFlight Connection Started
    17:44:11 SimConnect Connection Started
    17:44:11 Aircraft Connection Starting.....
    17:44:11 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    17:44:11 SimConnect: Event Received: SIM, 1
    17:44:11 SimConnect: Event Received: PAUSE, 0
    17:44:11 SimConnect: Event Received: VIEW, 2
    17:44:12 WinSock: Connected To localhost On Port 27016!
    17:44:12 LUA Processor: Started!
    17:44:12 Aircraft Connection Started
    17:44:12 Simconnect Version: 11.0.62651.3
    17:44:12 Aircraft FullName: Asobo_C172sp_AS1000
    17:44:12 SimConnect: Exception Received: OUT_OF_BOUNDS
    17:44:12 Synchronising Switches & Selectors .....
    17:44:13 SimConnect: Exception Received: OUT_OF_BOUNDS
    17:44:14 SimConnect: Exception Received: OUT_OF_BOUNDS
    17:44:15 SimConnect: Exception Received: OUT_OF_BOUNDS
  • This is definitely an incorrect GIT WASM module issue. Delete the existing pollypotsoftware-flightsimio-module in your community folder and manually install the one available in your account.
  • I've done that several times. Can you please email me the correct file.
  • Have you moved your community folder to somewhere else, so your old one is no longer monitored?
  • Hello Steve
    I believe they are right. I had to do an update and afterwards I had this problem. Everything seems to be working now.
    Many thanks Peter
  • Hello Steve
    Now I have the problem that the Goflight instruments don't work in the outside view.
    Everything is OK in the cockpit view. Can you give me an advice.
    Greetings Peter
