My GF MCP PRO is not responding while MSFS2020 for B737-800 is running . How can i fix this problem?
My GF mcp pro is not working properly when i turn the heading bug or courses. when i turn the heading bug at the msfs 2020 b737-800, the heading is respoding on my gf mcp pro. but when i turn the heading bug from gf mcp pro, msfs is not reponding.
i attached some pages of "GoFlight interface tool fs2020". please let me know how can i fix this problem.
thank you so much.
thank you so much.
Thank you for your reply. As you mentioned , i tried. but it didn't work.
For your informaion, i attached the screenshot.
please let know us how can i fix this problem.
Thank you.
Below is the GIT log.
22:33:03 GoFlight Connection Starting.....
22:33:03 SimConnect Connection Starting.....
22:33:03 GoFlight Connection Started
22:35:16 SimConnect Message Processing Started
22:35:16 SimConnect Connection Started
22:35:16 Aircraft Connection Starting.....
22:35:17 WinSock: Connected To 127.0.0.1 On Port 27016!
22:35:17 LUA Processor: Started!
22:35:17 Aircraft Connection Started
22:35:17 Simconnect Version: 11.0.62651.3
22:35:17 Aircraft FullName: Generic
22:35:28 SimConnect: Event Received: Start
22:35:28 SimConnect Receive Message Exception: startIndex는 문자열의 길이보다 클 수 없습니다.
매개 변수 이름: startIndex
22:35:55 SimConnect: Event Received: SIMSTOP, 0
22:35:55 SimConnect: Event Received: SIM, 0
22:35:55 PMDG SDK option is OK in FS2020
22:35:55 SimConnect: Event Received: Aircraft Type Changed
22:35:55 GoFlight Connection Starting.....
22:35:55 Synchronising Switches & Selectors .....
22:35:55 Synchronising Switches & Selectors: Waiting for SimConnect .....
22:35:55 SimConnect Message Processing Finished
22:35:56 SimConnect Connection Starting.....
22:35:56 Creating Bespoke Vars
22:35:56 Bespoke Vars Created
22:35:56 Importing Bespoke Variables
22:35:56 Bespoke Vars Assigned, Importing Bespoke Events
22:35:56 Bespoke Events Temp Imported
22:35:56 Bespoke Events Imported
22:35:56 Joystick Device Found: Logitech Extreme 3D
22:35:56 Joystick Device Found: T-Rudder
22:35:56 Device Found: USB Keyboard
22:35:56 Device Found: MCP Pro
22:35:57 SimConnect Message Processing Started
22:35:57 Mouse Device Found: 마우스
22:35:57 Keyboard Device Found: 키보드
22:35:57 Joystick Found Device 0: Logitech Extreme 3D
22:35:57 Device 0 Button Count: 12
22:35:57 Device 0 POV Count:1
22:35:57 Joystick Found Device 1: T-Rudder
22:35:57 Device 1 Button Count: 0
22:35:57 Device 1 POV Count:0
22:35:57 SimConnect Connection Started
22:35:57 Aircraft Connection Starting.....
22:35:57 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
22:35:57 SimConnect: Event Received: SIM, 1
22:35:57 SimConnect: Event Received: PAUSE, 1
22:35:57 GoFlight Connection Started
22:35:58 WinSock: Connected To 127.0.0.1 On Port 27016!
22:35:58 LUA Processor: Started!
22:35:58 Aircraft Connection Started
22:35:58 Simconnect Version: 11.0.62651.3
22:35:58 Aircraft FullName: PMDG 737-800BCF
22:36:07 SimConnect: Event Received: PAUSE, 0
22:36:27 SimConnect: Exception Received: OUT_OF_BOUNDS
22:36:27 SimConnect: Exception Received: ILLEGAL_OPERATION
22:36:28 Global LUA Event Running
22:36:28 Global Aircraft LUA Event Running
22:36:28 Synchronising Switches & Selectors Complete
22:46:35 Send Control Data: Too Many Retries
22:46:36 Send Control Data: Too Many Retries
22:46:37 Send Control Data: Too Many Retries
22:46:38 Send Control Data: Too Many Retries
22:46:39 Send Control Data: Too Many Retries
22:47:04 SimConnect: Event Received: PAUSE, 1
22:47:04 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
22:47:04 SimConnect: Event Received: SIMSTOP, 0
22:47:04 SimConnect: Event Received: SIM, 0
22:47:04 SimConnect: Event Received: PAUSE, 0
22:47:05 SimConnect: Event Received: SIMSTART, 0
22:47:05 SimConnect: Event Received: SIM, 1
22:47:07 SimConnect: Event Received: SIMSTOP, 0
22:47:07 SimConnect: Event Received: SIM, 0
22:47:08 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
22:47:13 SimConnect: Event Received: SIMSTART, 0
22:47:13 SimConnect: Event Received: SIM, 1
22:47:37 SimConnect: Event Received: PAUSE, 0
22:47:37 SimConnect: Event Received: PAUSE, 1
22:47:41 SimConnect: Event Received: PAUSE, 0
22:47:50 Send Control Data: Too Many Retries
22:47:51 Send Control Data: Too Many Retries
22:47:52 Send Control Data: Too Many Retries
22:47:53 Send Control Data: Too Many Retries
22:47:55 Send Control Data: Too Many Retries
22:47:56 Send Control Data: Too Many Retries
22:47:57 Send Control Data: Too Many Retries
22:47:58 Send Control Data: Too Many Retries
22:47:59 Send Control Data: Too Many Retries
22:48:10 Send Control Data: Too Many Retries
22:48:11 Send Control Data: Too Many Retries
22:48:12 Send Control Data: Too Many Retries
22:48:13 Send Control Data: Too Many Retries
22:48:14 Send Control Data: Too Many Retries
22:48:15 Send Control Data: Too Many Retries
22:48:16 Send Control Data: Too Many Retries
22:48:17 Send Control Data: Too Many Retries
22:48:18 Send Control Data: Too Many Retries
22:48:19 Send Control Data: Too Many Retries
22:48:20 Send Control Data: Too Many Retries
i have attached several screenshots for your understaning. please check it.
And i have also questions below.
1. "A new version is available" message is showing. how can i install it?
2. " applicaiton halted" message is showing. what does it mean and is it affected by pollypotsoftware for mcp pro?
3. my possible download number is only 11 left. if i erase the current software and download again, is it helpful to fix this problem?
please let me know.
Download GIT again from your account and reinstall. Make sure the GIT WASM module located in your community folder under the directory called pollypotsoftware-flightsimio-module\modules is dated 27th January 2023. You can download the GIT WASM module and install it manually into your community folder if necessary.
but how can i download GIT WASH module and intall it manually in my community folder.
even though i downloaded GIT WASH module, it requires another action..
Also i don't know how can i have activated the GIT WASH module.
please see the attached file.
Today, i installed the latest version(4.7.3.2) and "A new version is available" message is no longer showing.
but still same problem existes.
i found out that GIT WASM module located in my community folder under the directory called pollypotsoftware-flightsimio-module\modules is dated 27th January 2023 as below the screenshot.
please advise how can i fix this problem.
Thank you.
Buy the way, due to the distance between a monitor and MCP PRO,
i bought a usb3.0 usb connector(5GBPS, DC 5V, A type downstream and B type upsteam). BUT it doesn't work.
Pls let me know the specification for the usb connector or the extention cable.
thank you.
