GIT for FS 2020 wont start
Today when I click on the Git FS 2020 Icon I get a message that it wont start and a long message headed "Application Halted"
The invocation of the constructor on type 'A.AH' that matches the specific binding constraints threw an exception
It then lists 9 different "reasons
It then says
Inner Exception
Configuration System failed to initiate
listing about 19 reasons.
Unfortunately I cant copy the file but I have got it as an image file from a screen shot
All worked OK yesterday after installing the AIG Manager and Traffic Controller
It then says
Inner Exception
This won't delete any aircraft configs you have.
I cant seem to make it work,
In the Debug.txt it gives the following:
SimConnect Message Processing Started
WinSock: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:27015
LUA Processor: Connect Exception - Unable To Connect!
Is that a help?
If still no joy, delete Documents\GoFlight Interface Tool so GIT starts clean, but you will lose your config data.
