Device Tabs not enabled
Windows 10 with P3Dv4. the GFConfig is correct, the three leds are green but Devices Tabs are not enabled.
What can I do?
  • The tabs will become enabled when you have the aircraft cockpit/VC visible in the sim.
  • Sorry for my bad english...
    I did it but nothings happened.
    It seems like there is no link between P3Dv4 and GTI
    The column Aircraft says: Mode Generic, none
    Here the LOG:
    5:45:21 GoFlight Connection Starting.....
    15:45:21 SimConnect Connection Starting.....
    15:45:21 SimConnect Message Processing Started
    15:45:22 GoFlight Connection Started
    15:45:22 SimConnect Connection Started
    15:45:22 Aircraft Connection Starting.....
    15:45:23 WinSock: Connected To 127.0.0.1 On Port 27015!
    15:45:23 LUA Processor: Started!
    15:45:28 FSUIPC: Connection Failed: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione 127.0.0.1:8385
    15:45:28 Aircraft Connection Started
    15:45:28 Simconnect Version: 4.5.0.0
    15:45:28 Aircraft FullName: Generic
    15:45:28 Synchronising Switches & Selectors .....
    15:45:28 Synchronising Switches & Selectors: Waiting for SimConnect .....
    15:45:31 GoFlight Connection Starting.....
    15:45:31 SimConnect Message Processing Finished
    15:45:31 SimConnect Connection Starting.....
    15:45:32 GoFlight Connection Started
    15:45:32 SimConnect Message Processing Started
    15:45:33 SimConnect Connection Started
    15:45:33 Aircraft Connection Starting.....
    15:45:34 WinSock: Connected To 127.0.0.1 On Port 27015!
    15:45:34 LUA Processor: Started!
    15:45:38 FSUIPC: Connection Failed: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione 127.0.0.1:8385
    15:45:38 Aircraft Connection Started
    15:45:38 Simconnect Version: 4.5.0.0
    15:45:38 Aircraft FullName: Generic
    Thanks for any suggestion
  • That is odd. There are 2 versions of GIT for P3D. One is 64bit, the other is 32bit. Have you tried both versions and does the same problem remain?
  • Sorry for the delay in response.
    Yes, i tried both versions without success.
    I also tried to run GIT without Windows Firewall nor AVAST but devices tabs are not enabled
    Thanks for yours efforts..
  • I think you do not have the cockpit showing, i.e. ready to fly. This line indicates this:
