Device Tabs not enabled
Windows 10 with P3Dv4. the GFConfig is correct, the three leds are green but Devices Tabs are not enabled.
What can I do?
I did it but nothings happened.
It seems like there is no link between P3Dv4 and GTI
The column Aircraft says: Mode Generic, none
Here the LOG:
5:45:21 GoFlight Connection Starting.....
15:45:21 SimConnect Connection Starting.....
15:45:21 SimConnect Message Processing Started
15:45:22 GoFlight Connection Started
15:45:22 SimConnect Connection Started
15:45:22 Aircraft Connection Starting.....
15:45:23 WinSock: Connected To 127.0.0.1 On Port 27015!
15:45:23 LUA Processor: Started!
15:45:28 FSUIPC: Connection Failed: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione 127.0.0.1:8385
15:45:28 Aircraft Connection Started
15:45:28 Simconnect Version: 4.5.0.0
15:45:28 Aircraft FullName: Generic
15:45:28 Synchronising Switches & Selectors .....
15:45:28 Synchronising Switches & Selectors: Waiting for SimConnect .....
15:45:31 GoFlight Connection Starting.....
15:45:31 SimConnect Message Processing Finished
15:45:31 SimConnect Connection Starting.....
15:45:32 GoFlight Connection Started
15:45:32 SimConnect Message Processing Started
15:45:33 SimConnect Connection Started
15:45:33 Aircraft Connection Starting.....
15:45:34 WinSock: Connected To 127.0.0.1 On Port 27015!
15:45:34 LUA Processor: Started!
15:45:38 FSUIPC: Connection Failed: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione 127.0.0.1:8385
15:45:38 Aircraft Connection Started
15:45:38 Simconnect Version: 4.5.0.0
15:45:38 Aircraft FullName: Generic
Thanks for any suggestion
Yes, i tried both versions without success.
I also tried to run GIT without Windows Firewall nor AVAST but devices tabs are not enabled
Thanks for yours efforts..
