Georg
Today I tried to register GFDev.dll and I got a RegSvr32 error. I'll translate because it came in german language.
The module GFDev.dll has been loaded butthe Dll Register Server Entrypoint could not be found.
Please make sure that GFDev.dll is a valid .Dll or OCX file and try again!
How can I find out if my GFDev.dll is not corrupted?
THX
Georg
No chance to get GIT working. Could you provide GF Config 2.26 or GF Config 2.25. Lots of people having my problem recommend to try older versions.
GF Config recognizes all my GF modules correct and lets me configure them but I would like to bring MCPPRO and EFIS back to work with PMDG.
regards Georg
Add /log in the target field of the GIT icon. This will push the GIT log to disk at Documents\GoFlight Interface Tool to see if this provides any clues.
Also disable any firewall to see if that is blocking for some reason.
14:43:08 SimConnect Connection Starting.....
14:43:09 SimConnect Message Processing Started
14:43:09 GoFlight Worker Thread Failed: Die Eingabezeichenfolge hat das falsche Format.
14:43:10 SimConnect Connection Started
14:43:10 Aircraft Connection Starting.....
14:43:10 PMDG SDK option is OK in Prepar3D v4
14:43:10 SimConnect: Event Received: Aircraft Type Changed
14:43:10 SimConnect: Event Received: SIM, 1
14:43:10 SimConnect: Event Received: PAUSE, 1
14:43:10 SimConnect: Event Received: VIEW, 2
14:43:10 SimConnect Message Processing Finished
14:43:10 SimConnect Connection Starting.....
14:43:11 SimConnect Message Processing Started
14:43:12 SimConnect Connection Started
14:43:12 Aircraft Connection Starting.....
14:43:12 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
14:43:12 SimConnect: Event Received: SIM, 1
14:43:12 SimConnect: Event Received: PAUSE, 1
14:43:12 SimConnect: Event Received: VIEW, 2
14:43:13 WinSock: Connected To 127.0.0.1 On Port 27015!
14:43:13 LUA Processor: Started!
Additional Info:
- No additional security tools installed
- Windows11 firewall totally switched off
- GoFlight folder containing GFConfig and GIT is excluded from Windows 11 Defender scanning
Additional questions:
- Which version of vcredist is required?
- Which version of DotNet is required?
- Has JAVA Runtime to be installed?
regards Georg
First of all many, many thanks for your brilliant support! Finally I did it! In my case it wasn't a problem of software it was the USB hub I use.
I stopped trying and trying an trying and came back to systematic testing.
- I deinstalled GFConfig and GIT
- I disconnected all hardware
- I reinstalled GFconfig and GIT 32bit
- Starting GIT GoFlight LED went green, attaching GoFlight modules to the pcs USB Ports GIT went GREEN and recognized the correct number and type of GF modules. Attaching the USB Hub GIT came up and freezes as usual during the last weeks.
- I continue now with testing other USB hubs or USB pc cards and I am quite sure things will work.
regards Georg
The rotary selector does not change values in the PMDGaircraft and the display on MCPPRO for the vertical speed stays dark.
What to do?
Georg
regards Georg
