When HoneyComb Yoke is connected, my GF-MCP PRO does work for msfs2020 b737-800.
Hello,
I purchased honycomb yoke recently and when i connected it to my PC for msfs2020,
My GF-MCP PRO doesn't work(no led light, not responding)
Please let me know the how can i set the GF MCP PRO with HoneyComb hardware.
Thank you
Thank you
Thank you for your replay.
I checked that it was originally the unticked “enable joysticks”.
so please let me know another instruction to activate my gf mcp pro with honeycomb bravo.
and before activating msfs 2020, it was originally unticked "enable joysticks". So there is nothing to do to fix this problem.
please see the picture and let me know more specifically.
Thank you.
06:22:04 GoFlight Connection Starting.....
06:22:04 SimConnect Connection Starting.....
06:22:04 GoFlight Connection Started
06:24:43 SimConnect Message Processing Started
06:24:43 SimConnect Connection Started
06:24:43 Aircraft Connection Starting.....
06:24:44 WinSock: Connected To localhost On Port 27016!
06:24:44 LUA Processor: Started!
06:24:45 Aircraft Connection Started
06:24:45 Simconnect Version: 11.0.62651.3
06:24:45 Aircraft FullName: Generic
06:24:45 Synchronising Switches & Selectors .....
06:24:45 Synchronising Switches & Selectors: Waiting for SimConnect .....
06:24:52 SimConnect: Event Received: Start
06:24:52 SimConnect Receive Message Exception: startIndex는 문자열의 길이보다 클 수 없습니다.
매개 변수 이름: startIndex
*At this moment, it is the unticked “enable joysticks”.
Then 1~2 minutes later, "GoFlight interface tool FS2020" seems to stop. i can't click or more it from a screen.
Below is when "GoFlight interface tool FS2020" seems to stop.
And the below is the screen when i fly B737-800 via MSFS2020.
Please let me know more specifically.
Thank you.
HM Song,
I tried as you suggested.
<Gf mcp connected directly to PC and Honeycomb conned to the USB HUB>
But still not working.
So i connected GF MCP PRO to PC and disconnected Honeycomb from PC.
But it was not working either.
Do I have to erase the current gf mcp pro software and then reinstall it?
Mcp pro is connected to pc and Honeycomb is connected to usb hub.
but it looks like same problem.
Below is the "SETTING" page of GIT FS2020.
It is totally different compared with the normal gf mcp pro(when it functioned normally) and "MCPPRO" page of GIT FS2020 is not activated, so i can't open it or click it as before.
and when msfs starts, below GIT LOG is showing and then GIT FS2020 Stops working(i can't click or move)
15:12:27 GoFlight Connection Starting.....
15:12:27 SimConnect Connection Starting.....
15:12:27 GoFlight Connection Started
15:24:48 SimConnect Message Processing Started
15:24:48 SimConnect Connection Started
15:24:48 Aircraft Connection Starting.....
15:24:50 WinSock: Connected To localhost On Port 27016!
15:24:50 LUA Processor: Started!
15:24:50 Aircraft Connection Started
15:24:50 Simconnect Version: 11.0.62651.3
15:24:50 Aircraft FullName: Generic
15:24:50 Synchronising Switches & Selectors .....
15:24:50 Synchronising Switches & Selectors: Waiting for SimConnect .....
15:25:01 SimConnect: Event Received: Start
15:25:01 SimConnect Receive Message Exception: startIndex는 문자열의 길이보다 클 수 없습니다.
15:25:01 SimConnect: Event Received: SIM, 1
15:25:01 SimConnect: Event Received: PAUSE, 1
15:25:01 SimConnect: Event Received: VIEW, 0
For your informaion, please see the below.
I have " wasm" program but when i click to activate it, "playback error" comes. please see the below.
Also, I am also using Logitech microsoft flight radio panel and Thrustmaster boeing yoke. these are connected to pc and usb hub.
please let me know how can i fix this problem.
Thank you.
And Tobii eye tracker is also connected to pc.
please see the attached file and let me know how can i fix this problem.
thank you.
below is the setting page before staring msfs2020.
below i the setting page after staring msfs2020.
and please see the next commnet.
07:07:57 GoFlight Connection Starting.....
07:07:57 SimConnect Connection Starting.....
07:07:57 GoFlight Connection Started
07:08:17 Joystick Device Found: Logitech Extreme 3D
07:08:17 Joystick Device Found: T-Rudder
07:08:17 FP Device Found: TCA YOKE BOEING
07:08:17 FP Device Found: Bravo Throttle Quadrant
07:08:17 Device Found: MCP Pro
07:08:17 Device Found: USB Keyboard
07:08:17 Mouse Device Found: 마우스
07:08:17 Keyboard Device Found: 키보드
07:08:17 Joystick Found Device 0: Logitech Extreme 3D
07:08:17 Device 0 Button Count: 12
07:08:17 Device 0 POV Count:1
07:08:17 Joystick Found Device 1: T-Rudder
07:08:17 Device 1 Button Count: 0
07:08:17 Device 1 POV Count:0
07:08:17 Joystick Found Device 2: TCA YOKE BOEING
07:08:17 Device 2 Button Count: 18
07:08:17 Device 2 POV Count:1
07:08:17 Joystick Found Device 3: Bravo Throttle Quadrant
07:08:17 Device 3 Button Count: 48
07:08:17 Device 3 POV Count:0
07:08:18 Joystick Device Found: Logitech Extreme 3D
07:08:18 Joystick Device Found: T-Rudder
07:08:18 FP Device Found: TCA YOKE BOEING
07:08:18 FP Device Found: Bravo Throttle Quadrant
07:08:18 Device Found: MCP Pro
07:08:18 Device Found: USB Keyboard
07:08:18 Mouse Device Found: 마우스
07:08:18 Keyboard Device Found: 키보드
07:08:18 Joystick Found Device 0: Logitech Extreme 3D
07:08:18 Device 0 Button Count: 12
07:08:18 Device 0 POV Count:1
07:08:18 Joystick Found Device 1: T-Rudder
07:08:18 Device 1 Button Count: 0
07:08:18 Device 1 POV Count:0
07:08:18 Joystick Found Device 2: TCA YOKE BOEING
07:08:18 Device 2 Button Count: 18
07:08:18 Device 2 POV Count:1
07:08:18 Joystick Found Device 3: Bravo Throttle Quadrant
07:08:18 Device 3 Button Count: 48
07:08:18 Device 3 POV Count:0
07:08:20 Joystick Device Found: Logitech Extreme 3D
07:08:20 Joystick Device Found: T-Rudder
07:08:20 FP Device Found: TCA YOKE BOEING
07:08:20 FP Device Found: Bravo Throttle Quadrant
07:08:20 Device Found: MCP Pro
07:08:20 Device Found: USB Keyboard
07:08:20 Mouse Device Found: 마우스
07:08:20 Keyboard Device Found: 키보드
07:08:20 Joystick Found Device 0: Logitech Extreme 3D
07:08:20 Device 0 Button Count: 12
07:08:20 Device 0 POV Count:1
07:08:20 Joystick Found Device 1: T-Rudder
07:08:20 Device 1 Button Count: 0
07:08:20 Device 1 POV Count:0
07:08:20 Joystick Found Device 2: TCA YOKE BOEING
07:08:20 Device 2 Button Count: 18
07:08:20 Device 2 POV Count:1
07:08:20 Joystick Found Device 3: Bravo Throttle Quadrant
07:08:20 Device 3 Button Count: 48
07:08:20 Device 3 POV Count:0
07:10:49 SimConnect Message Processing Started
07:10:49 SimConnect Connection Started
07:10:49 Aircraft Connection Starting.....
07:10:54 WinSock: Connection Failed: 대상 컴퓨터에서 연결을 거부했으므로 연결하지 못했습니다 127.0.0.1:27016
07:10:54 LUA Processor: Connect Exception - Unable To Connect!
07:10:54 Aircraft Connection Started
07:10:54 Simconnect Version: 11.0.62651.3
07:10:54 Aircraft FullName: Generic
07:10:54 Synchronising Switches & Selectors .....
07:10:54 Synchronising Switches & Selectors: Waiting for SimConnect .....
07:11:01 SimConnect: Event Received: Start
07:11:01 SimConnect Receive Message Exception: startIndex는 문자열의 길이보다 클 수 없습니다.
so when i started msfs2020, GIT Stopped as below screen shot.
and below one is
please let me know the meaning and the cause of this message.
Unable to open item for playback (Unsupported file format):
"C:\Users\aa\AppData\Roaming\Microsoft Flight Simulator\Packages\Community\pollypotsoftware-flightsimio-module\modules\FlightSimIOModuleWASM.wasm"
what does it mean?
Below is the LOG after deleting the directory C:\Users\your username\AppData\Local\PollyPot_Software.
15:23:39 GoFlight Connection Starting.....
15:23:39 SimConnect Connection Starting.....
15:23:39 GoFlight Connection Started
15:25:40 SimConnect Message Processing Started
15:25:41 SimConnect Connection Started
15:25:41 Aircraft Connection Starting.....
15:25:42 WinSock: Connected To localhost On Port 27016!
15:25:42 LUA Processor: Started!
15:25:42 Aircraft Connection Started
15:25:42 Simconnect Version: 11.0.62651.3
15:25:42 Aircraft FullName: Generic
15:25:42 Synchronising Switches & Selectors .....
15:25:42 Synchronising Switches & Selectors: Waiting for SimConnect .....
15:25:49 SimConnect: Event Received: Start
15:25:49 SimConnect Receive Message Exception: startIndex는 문자열의 길이보다 클 수 없습니다.
I think that the below message is the cause of this problem.
Translate from Korean to English.
Cannot be greater than the length of the string.
Parameter name: startIndex
please see and let me know what does it mean.
And same message when adtivated FlightSimIOModuleWASM.wasm
You cannot play a WASM module.
Does GIT now work correctly?
10:39:33 GoFlight Connection Starting.....
10:39:33 SimConnect Connection Starting.....
10:39:34 GoFlight Connection Started
10:41:42 SimConnect Message Processing Started
10:41:42 SimConnect Connection Started
10:41:42 Aircraft Connection Starting.....
10:41:43 WinSock: Connected To localhost On Port 27016!
10:41:43 LUA Processor: Started!
10:41:43 Aircraft Connection Started
10:41:43 Simconnect Version: 11.0.62651.3
10:41:43 Aircraft FullName: Generic
10:41:43 Synchronising Switches & Selectors .....
10:41:43 Synchronising Switches & Selectors: Waiting for SimConnect .....
10:41:54 SimConnect: Event Received: Start
10:41:54 SimConnect Receive Message Exception: startIndex는 문자열의 길이보다 클 수 없습니다.
10:41:54 SimConnect: Event Received: PAUSE, 1
10:41:54 SimConnect: Event Received: VIEW, 0
WHAT DOES "STARTINDEX" MEAN?
What is the virtual cockpit?
what does ZIP IT UP mean?
I already copied the whole GIT LOG with PMDG loaded and sent it before.
I can’t understand your message. please let me know more specifically. I need the detailed instructions.
Forget Zipping it up, just post as before, but all of it, including using the MCP Pro.
I need to see the log again because things have changed.
11:06:07 GoFlight Connection Starting.....
11:06:07 SimConnect Connection Starting.....
11:06:07 GoFlight Connection Started
11:14:23 SimConnect Message Processing Started
11:14:24 SimConnect Connection Started
11:14:24 Aircraft Connection Starting.....
11:14:25 WinSock: Connected To localhost On Port 27016!
11:14:25 LUA Processor: Started!
11:14:25 Aircraft Connection Started
11:14:25 Simconnect Version: 11.0.62651.3
11:14:25 Aircraft FullName: Generic
11:14:25 Synchronising Switches & Selectors .....
11:14:25 Synchronising Switches & Selectors: Waiting for SimConnect .....
11:14:44 SimConnect: Event Received: Start
11:14:44 SimConnect Receive Message Exception: startIndex는 문자열의 길이보다 클 수 없습니다.
11:14:44 SimConnect: Event Received: PAUSE, 1
11:14:44 SimConnect: Event Received: VIEW, 0
FOR YOUR INFORMATION, please see below it.
Is it a pmdg problem?
Is there anything to change or modify in msfs2020 option page (general options, assistance options, control options)?
Also, this behaviour has been seen when GoFlight devices are plugged into incompatible USB ports. Did you connect the MCP Pro to a different USB port when connecting your yoke?
Now mcp pro and york are connected to the pc, not usb port.
11:35:16 GoFlight Connection Starting.....
11:35:16 SimConnect Connection Starting.....
11:35:17 GoFlight Connection Started
11:37:13 SimConnect Message Processing Started
11:37:13 SimConnect Connection Started
11:37:13 Aircraft Connection Starting.....
11:37:16 WinSock: Connection Failed: 대상 컴퓨터에서 연결을 거부했으므로 연결하지 못했습니다 127.0.0.1:27015
11:37:16 LUA Processor: Connect Exception - Unable To Connect!
11:37:16 Aircraft Connection Started
11:37:16 Simconnect Version: 11.0.62651.3
11:37:16 Aircraft FullName: Generic
11:37:16 Synchronising Switches & Selectors .....
11:37:16 Synchronising Switches & Selectors: Waiting for SimConnect .....
11:37:20 SimConnect: Event Received: Start
11:37:20 SimConnect Receive Message Exception: startIndex는 문자열의 길이보다 클 수 없습니다.
11:37:30 SimConnect: Event Received: SIMSTOP, 0
11:37:30 SimConnect: Event Received: SIM, 0
11:37:30 PMDG SDK option is OK in FS2020
11:37:30 SimConnect: Event Received: Aircraft Type Changed
11:37:30 GoFlight Connection Starting.....
11:37:30 SimConnect Message Processing Finished
11:37:31 SimConnect Connection Starting.....
11:37:31 Creating Bespoke Vars
11:37:31 Bespoke Vars Created
11:37:31 Importing Bespoke Variables
11:37:31 Bespoke Vars Assigned, Importing Bespoke Events
11:37:31 Bespoke Events Temp Imported
11:37:31 Bespoke Events Imported
11:37:32 GoFlight Connection Started
11:37:32 SimConnect Message Processing Started
11:37:32 SimConnect Connection Started
11:37:32 Aircraft Connection Starting.....
11:37:32 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
11:37:32 SimConnect: Event Received: SIM, 1
11:37:32 SimConnect: Event Received: PAUSE, 1
11:37:32 SimConnect: Event Received: VIEW, 0
11:37:35 WinSock: Connection Failed: 대상 컴퓨터에서 연결을 거부했으므로 연결하지 못했습니다 127.0.0.1:27015
11:37:35 LUA Processor: Connect Exception - Unable To Connect!
11:37:35 Aircraft Connection Started
11:37:35 Simconnect Version: 11.0.62651.3
11:37:35 Aircraft FullName: PMDG 737-800
11:37:36 SimConnect: Event Received: PAUSE, 0
11:38:09 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
11:38:09 SimConnect: Event Received: SIMSTOP, 0
11:38:09 SimConnect: Event Received: SIM, 0
11:38:09 SimConnect: Event Received: PAUSE, 1
11:38:09 SimConnect: Event Received: SIMSTART, 0
11:38:09 SimConnect: Event Received: SIM, 1
11:38:12 SimConnect: Event Received: SIMSTOP, 0
11:38:12 SimConnect: Event Received: SIM, 0
11:38:12 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
11:38:15 SimConnect: Event Received: SIMSTART, 0
11:38:15 SimConnect: Event Received: SIM, 1
11:38:40 SimConnect: Event Received: PAUSE, 0
11:38:40 SimConnect: Event Received: PAUSE, 1
11:38:57 SimConnect: Event Received: PAUSE, 0
11:38:57 SimConnect: Event Received: VIEW, 2
11:39:07 Synchronising Switches & Selectors Complete
11:39:18 SimConnect: Event Received: PAUSE, 1
11:39:20 SimConnect: Event Received: PAUSE, 0
11:44:40 SimConnect: Event Received: PAUSE, 1
but still no light on mcp pro when i started msfs2020. So i can't use it.
please see the below and please let me know whether it is a correct configuration or not?
mcp pro is not working either.
Futhermore, pmdg has a problem with updating. after updating, mini bar is disppeared as below.
It looks good now, working properly.
By the way, i am planning to erase the current pmdg program and reinstall it due to updating issues.
Before erase or after reinstall the PMDG, Do i need to do something for GIT Program?
i really appriciate your support!
have a nice day!
