Bespoke Vars Import Exception
                    i have xplane 12 and Zibo 737 Everything was working fine, but today I got a new message
"20:48:42 GoFlight Connection Starting.....
20:48:42 X-Plane Connection Starting.....
20:48:42 GoFlight Connection Started
20:48:43 X-Plane Connection Started
20:48:43 Aircraft Connection Starting.....
20:48:43 X-Plane: Event Received: Aircraft Loaded/Flight Loaded
20:48:46 WinSock: Connected To localhost On Port 27015!
20:48:46 LUA Processor: Started!
20:48:46 Aircraft Connection Started
20:48:46 Synchronising Switches & Selectors .....
20:48:46 Synchronising Switches & Selectors: Waiting for X-Plane .....
20:49:15 LvarNamesUpdated!
20:49:15 Creating Bespoke Vars
20:49:15 Bespoke Vars Created
20:49:15 Importing Bespoke Variables
20:49:15 Bespoke Vars Import Exception: '.', hexadecimal value 0x00, is an invalid character. Line 1, position 1.
I tried deleting the program and re-installing it again, the same message and the same problem, deleting the registry for the program. deleting C:\Users\\AppData\Local\PollyPot_Software
the same problem
Is there a solution to this problem?
the same problem
Ideally restore the file from a backup you may have (you can also check if the Backup subdirectory in Documents\GoFlight Interface Tool has a valid version of the file), or delete it and allow GIT to recreate it.
You may need to reimport the Zibo profile if it no longer works correctly after doing this.
